Author Topic: Shift Key in I-PAC  (Read 8932 times)
HHH
  • Last login:June 28, 2021, 11:54:30 am
Shift Key in I-PAC
« on: August 03, 2017, 07:23:57 am »
Hi, i am building an upright arcade cabinet. Now i have finished and i am configuring the I-PAC2 with the Winipac V2 software.
But there is a problem. I dont know how works the "Shift" button in I-PAC.
It's supposed that the Shift key in I-PAC2 is the 1P Start.
And it's supposed too that i can change that Shift key (i dont know how).
Well i configure the 1P SW1 to be the "J" and to be the "u" when Shifted.
For instance, if i press once that key i get back the "J", but when i press 1P Start and the same key, i dont get bak the "u".
How can i make it work?
I am stucked because i need several keys to be shifted.
Thanks in advnace and sorry for my bad english
Titchgamer
Re: Shift Key in I-PAC
« Reply #1 on: August 03, 2017, 07:37:03 am »
The shift key has to be held down to work the same as a shift key on a keyboard.
The keys can be reassigned in the software.
HHH
« Reply #2 on: August 03, 2017, 07:57:51 am »
Yes, i know that, but when i press the "Shift" key (1P Start which is key "1") nothing happens
I hold down the 1P Start + 1SW1 and only the number "1" is written down in the notepad (which i use to test keys)
I have seen in Ultimarc webpage this:
"In programmable mode you can assign any input to be the shift button and you can program all of the buttons to have shifted codes"
How can i go to programmable mode to assign any other input to be the shift button?
Thanks again
fablog
  • Last login:January 04, 2026, 04:27:15 pm
« Reply #3 on: August 03, 2017, 08:02:53 am »
« Last Edit: August 03, 2017, 08:04:58 am by fablog »
HHH
« Reply #4 on: August 03, 2017, 08:07:10 am »
Yes, i have configured all the buttons with that.
I am using this software:
http://www.ultimarc.com/winipacv2setup.exe
I have firmware version 1.44
And the version of the WinIPAC is the 1.0.8.8 (i use Windows 10)
P.D.: i forgot to say i had an IPAC-2 3 years ago, and i configured that without any problems, including the Shift keys. They worked flawlessly
« Last Edit: August 03, 2017, 08:09:00 am by HHH »
nexusmtz
« Reply #5 on: August 03, 2017, 06:45:13 pm »
The first thing to do when the Shift key doesn't work is to confirm that no other key is stuck closed. Windows will not see a stuck key if it is already closed when you start windows or connect the device, so you might not notice, and the shift function will not work if any other key is already down.
Test all of your buttons by pressing them down once for one second each. If any key does not respond until you release it, either's that's the stuck key, or it's the key that you have assigned for shift. In other words, every key except the shift key should send its assigned code when you press it DOWN, not when you release it.
Also, check that you have your wire connected to the NO tab of all buttons, and not the NC tab. Having any button on the NC tab will cause this problem.
HHH
« Reply #6 on: August 04, 2017, 02:12:01 am »
ok it's solved
i was confusing about the "shifted" and the "IPAC Shift" in WinIPAC V2
i ticked the IPAC Shift in all the buttons i wanted to be Shifted, so the operation was inaccurate
Now it' all solved. Only one tick in 1P Start in the IPAC Shift box.
Thanks to all
Scooby
  • Last login:June 01, 2020, 10:15:07 am
« Reply #7 on: August 05, 2017, 03:47:25 am »
I have a "shift" question too...
What happens if I hardwire the "shift button" input and one other "button" input together on one single button? Will it trigger the shifted function of that key? This way I could use more functions without pressing two buttons at once. You know what I mean?
05SRT4
  • Check out my Pow Pow
« Reply #8 on: August 05, 2017, 04:07:17 am »
Add more buttons so you dont have to press 2 at the same time? Doesn't sound efficient
Titchgamer
« Reply #9 on: August 05, 2017, 04:33:46 am »
And the point of that would be what?
You would just program the switch to be the single key press you wanted as the shifted key.
  • Last login:Today at 04:07:30 pm
« Reply #10 on: August 05, 2017, 04:53:14 am »
Sounds like you want to have a dedicated button for a shifted function like the green "P1 Coin" button below.
To convert the diagram for IPac, the "Shift (D7)" input port is "P1 Start".
With no buttons pushed, the input ports are all at a logic high. (5v)
When you press the green button:
- Ground is applied to the cathode (band end) of the two lower diodes
- Both diodes are forward biased
- They conduct and apply ground to both the Shift port and P1B2 port ==> P1B2 shifted function
When you press the blue button:
- Ground is applied to the anode (non-band end) of the bottom diode
- The diode is not forward biased so it does not conduct ==> blocks the ground from reaching the cathode (band end) of the other diode
- Ground is also applied to P1B2 port ==> P1B2 normal function
If you only need one dedicated button, you can use the "backwards wiring" trick mentioned here for controlling MagnaSave/Upper Flipper with one pinball button.
(more than one dedicated button for shifted functions requires using diodes like below)
Scooby
« Reply #11 on: August 05, 2017, 04:59:52 am »
I am planning to add a couple of miniature "service" buttons to my control panel. Like "load game state", "save game state", "vol up", "vol down", "pause", etc.
and my IPac is short on inputs...
Scooby
« Reply #12 on: August 05, 2017, 05:11:57 am »
Yes, that's exactly what I want! Thanks PL1!
I had to take a second look at the schematics. Never saw such a symbol for a diode. ;)
