Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 267374 times)
albmm
  • Last login:April 30, 2025, 07:39:06 am
  • Weche OK Baby user
Re: GroovyMAME/ARCADE32/64 custom build
« Reply #440 on: December 12, 2024, 04:54:28 am »
I'll try to fix this. Maybe it won't be hard to do.
Thanks! I will be pending of future releases.
haynor666
  • Last login:Yesterday at 05:45:00 pm
  • retro maniac
« Reply #441 on: December 15, 2024, 03:13:01 pm »
Just like I mentioned on discord channel - nothing needs to be fixed. My build has no nag but patches are without no nag.
Version 272 is out.
haynor666
  • retro maniac
« Reply #442 on: December 30, 2024, 09:23:20 am »
Looks like code for neogep patch needs update from august. Nobody realized that some games are missing first two vertical lines from left :)
Fix will be with version 273.
haynor666
  • retro maniac
« Reply #443 on: January 02, 2025, 12:20:10 pm »
Version 273 is out.
Lots of changes in neogeo and system1.
xyzhz
  • Last login:Yesterday at 07:35:37 pm
« Reply #444 on: January 10, 2025, 07:06:29 pm »
patches_273
273_03_various_fixes.diff
273_04_various_changes.diff
GroovyMAME-gm0273sr221d source code Mame-0273 is as follows
« Last Edit: January 12, 2025, 08:41:56 pm by xyzhz »
haynor666
  • retro maniac
« Reply #445 on: January 19, 2025, 09:27:40 am »
Try patch -p0 -E for my patches
patch -p1 is for only groovymame patch
sean_skroht
  • Last login:March 06, 2025, 02:05:36 am
« Reply #446 on: February 12, 2025, 12:20:47 am »
Hi haynor666,
Thanks for maintaining your custom version of Groovymame.
I had been using 0.272 and I am now using 0.273. Unfortunately, both versions (and possibly earlier versions but I haven't used them) display an error when running Galaxian.
The error is as follows:
Code: [Select]
Driver jumpbugbc (file galaxian.cpp): 2 errors, 0 warnings
Errors:
   Zilog Z80 device 'maincpu': program space memory map entry writes to nonexistent device ':cust'
Driver jumpbugbrf (file galaxian.cpp): 2 errors, 0 warnings
Errors:
This error doesn't appear in mainline MAME nor in Calamity's Groovymame. Galaxian still runs but the error box is annoying.
Thanks mate.   :D
haynor666
  • retro maniac
« Reply #447 on: February 13, 2025, 02:43:07 pm »
That's because this game uses extra sound for jump. It's imported from ARCADE32/64. Perhaps I did this wrong or it's just work like this :/
haynor666
  • retro maniac
« Reply #448 on: February 15, 2025, 07:22:00 am »
Version 274 is out.
albmm
« Reply #449 on: March 18, 2025, 09:06:12 am »
- visible area modifications for many games in neogeo driver (mostly from 320x224 to 304x224 but for four games even to 288x224 - Zed Blade, Goal!Goal!Goal!, Gururin, Zupapa)
Hi friend. Take acount that there are some 312x224 neogeo games:
- Ninja Combat
- 2020 Super Baseball
- Last Resort
- Panic Bomber
I have tested Last Resort and your patch cuts some lines of the ingame area.
Besides this, a fix for Gradius 4 would be great.
Thanks for your work!
« Last Edit: March 26, 2025, 09:05:38 am by albmm »
Endprodukt
  • Last login:Yesterday at 09:13:26 am
« Reply #450 on: March 21, 2025, 08:17:53 pm »
Are we going to see .275 by any chance? That mame version has some major fixes to some drivers :)
haynor666
  • retro maniac
« Reply #451 on: March 26, 2025, 03:56:03 pm »
In the works ;)
- Ninja Combat
- Last Resort
- Panic Bomber
Should be fine for most games in version 275.
« Last Edit: March 26, 2025, 03:57:48 pm by haynor666 »
haynor666
  • retro maniac
« Reply #452 on: March 27, 2025, 11:44:21 am »
Version 275 is out.
Endprodukt
« Reply #453 on: April 04, 2025, 02:54:19 am »
haynor666
  • retro maniac
« Reply #454 on: April 20, 2025, 01:00:05 pm »
Version 276 is out.
haynor666
  • retro maniac
« Reply #455 on: May 04, 2025, 05:59:42 am »
Version 277 is out. This time almost instantly :)
Endprodukt
« Reply #456 on: August 19, 2025, 10:36:28 am »
278 and 279 are out! :applaud:
haynor666
  • retro maniac
« Reply #457 on: August 22, 2025, 03:30:55 am »
Version 278 is out.
Version 279 will be available soon ;)
Endprodukt
« Reply #458 on: August 22, 2025, 03:42:04 am »
Thank you very very much
haynor666
  • retro maniac
« Reply #459 on: August 22, 2025, 09:45:52 am »
And version 279 is out ;)
Endprodukt
« Reply #460 on: October 05, 2025, 09:17:45 am »
281 pretty please 🥺?
Before I keep bothering you, can I compile this myself?
haynor666
  • retro maniac
« Reply #461 on: October 19, 2025, 09:17:58 am »
Version 280 is out. Re-create diffs and compile version 281 will take probably 3 or 4 hours.
Endprodukt
« Reply #462 on: October 19, 2025, 09:57:28 am »
It's very much appreciated!
haynor666
  • retro maniac
« Reply #463 on: October 19, 2025, 02:01:19 pm »
Version 281 is out.
Endprodukt
« Reply #464 on: October 19, 2025, 02:22:03 pm »
You are the best, thank you so much!
