Author Topic: GroovyMAME/ARCADE32/64 custom build  (Read 359980 times)
haynor666
  • Last login:May 01, 2026, 01:37:39 pm
  • retro maniac
« on: July 19, 2017, 03:22:12 pm »
Here I will post my own GroovyMAME build based on official sources plus extra modifications imported from ARCADE http://arcade.mameworld.info (new derrative based on MAMEUIFX) and no nag patch. Some of those changes created by me.
Differences against standard GroovyMAME:
- no nag  - no loading screens or disclaimer info (use option 'skip_gameinfo 1' in mame.ini to activate this function)
Sound modifications:
- sample "fire" support in Pleiads
- enable stereo sound in Truxton 2
- QS1000 volume boots (games using this chip has louder audio output)
- audio level fix for m72 driver removed in 232
- audio level fix for Side Arms
- frequency modification for several audio chips for proper audio speed (Aliens, Crime Fighters, Simpsons, Vendetta) removed in version 239
- fix for Crude Buster, Dark Seal and Vapor Trail (now sound does not change it's pitch/speed during attract mode/game) removed in version 213
- Better NMI value for Jail Break (proper audio pitch?) removed in version 254
- fix for Gradius/Nemesis (discrete emulation is bypassed so no strange audio during play) removed
Video modifications:
- hack for fixing sprites in neogeo driver removed - this was always complicated to keep and could cause trouble in driver
- removed custom position and size in astrocde and cidelsa drivers (looks very bad on TV/Arcade monitor)
- restored resolution 256x240 (from 240x240) in remaining games in btime,scregg drivers
- video fix for Metamorpic Force (proper offsets) removed in version 254
- small colours fix in nemesis driver (games have now slightly more brighter picture, seems to be more accurate)
- visible area modifications in in ssv driver (changed Air Blade; Dyna Gear)
- visible area modifications for many games in neogeo driver (mostly from 320x224 to 304x224 but for four games even to 288x224 - Zed Blade, Goal!Goal!Goal!, Gururin, Zupapa)
- visible area modification for X-Men,
- visible area modification Go Go Mr. Yamaguchi [not in ARCADE32/64] removed for now - needs source update
- visible area modification Super Contra, Gang Busters, Thunder Cross, Teenage Mutant Hero Turtles, Bells'n'Whistles [not in ARCADE32/64]
- visible area modification for Battle Rangers, Double Dragon, Double Dragon II, Thunder Strike, China Gate, Garyo Retsuden [not in ARCADE32/64]
- visible area modification for Express Raider, Exzisus, Liberation, Nova 2001, Rock'n'Rage, Riot City, Wonder Boy 3, Aurail [not in ARCADE32/64]
- visible area modification for Mad Crasher, Gladiator 1984, Super Cross II, Jungle King, Sea Fighter Poseidon, Xain'n Sleena [not in ARCADE32/64]
- visible area modification for many games in namcona1 driver [not in ARCADE32/64]
- visible area modification for many games in system1 driver [not in ARCADE32/64]
- some video fixes in taito_f3 driver (continue screen in Greed Seeker is now visible, the same goes to intro text in Arabian Nights) removed in version 266
Misc modifications:
- slow rendering fix for namconb1
- more accurate video timings in Green Beret removed in version 254
- swapped some IRQ handling in megasys1 driver
- made Primal Rage 2 working removed in version 275
32bit build modifications:
- d3d fix for old video cards removed from version 216
GroovyMAME source (up to version 227): HERE
GroovyMAME source (from version 228): HERE
No nag source: HERE
All files (builds, sources) are now HERE
NOTE. Those are only main EXE files. You are still need remaing files from official mame pack.
« Last Edit: April 27, 2026, 04:05:47 pm by haynor666 »
mdd45
  • Last login:July 22, 2025, 06:03:10 pm
Re: GroovyMAME/ARCADE32
« Reply #1 on: July 19, 2017, 06:10:47 pm »
Thank you!!!
Paradroid
  • Last login:April 24, 2026, 06:16:44 pm
    • SCART Hunter
« Reply #2 on: July 19, 2017, 07:53:53 pm »
Unreal!
Sent from my SM-A300Y using Tapatalk
My MAME/SCART/CRT blog: SCART Hunter
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #3 on: July 20, 2017, 02:58:56 am »
very nice, thanks for sharing!
Is this an arcade-only build or does it also contain MESS?
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« Reply #4 on: July 20, 2017, 06:59:57 am »
See top of OP's post, looks like it's based on Arcade, a fork of MAMEUIFX, so no MESS.
keropi
« Reply #5 on: July 20, 2017, 09:40:36 am »
I am not familiar with "arcade" so it's good to hear there is no MESS in this one :)
haynor666
  • retro maniac
« Reply #6 on: July 20, 2017, 11:10:37 am »
MAME = old MAME +MESS so my build is with MESS part as well just like Groovymame.
keropi
« Reply #7 on: July 20, 2017, 11:42:56 am »
^ allright then , thanks for the clarification :)
haynor666
  • retro maniac
« Reply #8 on: July 20, 2017, 12:47:38 pm »
For clarification - ARCADE is build upon old MAMEUIFX code. MAMEUIFX was arcade only build so ARCADE is also MAME with only arcade part, hence the new simple name.
Calamity
  • Moderator
  • Last login:Today at 05:01:58 am
  • Quote me with care
« Reply #9 on: July 20, 2017, 02:42:07 pm »
Glad to see this hybridisation.
Steps to create a log:
marcelosofth
  • Last login:November 12, 2018, 05:54:46 am
« Reply #10 on: July 20, 2017, 03:26:54 pm »
Yesssssssssssssssss, vivaaaaaaaaaaa, tks my friend (Windows XP - 32bits foreverrrrrr)  :applaud: :cheers:
Nodoyuna
  • Last login:November 29, 2025, 11:48:41 am
« Reply #11 on: July 21, 2017, 05:56:15 am »
Tried yesterday and works great
Thanks a lot, it's always better to have GM in sync with the latest official version
Recapnation
  • Last login:May 03, 2026, 05:29:57 am
    • Eiusdemmodi
« Reply #12 on: July 21, 2017, 11:58:45 am »
What does this achieve, exactly? Fixing Terry's stage in Garou?
haynor666
  • retro maniac
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #14 on: July 22, 2017, 06:18:50 am »
Thank you haynor. I will try this out asap.
Recapnation
    • Eiusdemmodi
« Reply #15 on: July 22, 2017, 07:31:37 am »
It's sad they're fixing non-bugs whereas this remains for so many years. Shouldn't be too hard to figure out a hack -- MAME must be the only emulator where you find it.
But hey, what do I know.
totozero
  • Last login:June 07, 2023, 07:36:05 am
« Reply #16 on: July 23, 2017, 05:30:51 pm »
Hi haynor,
thanks for making this build.
Would it be possible to make another d3dex 64 version with a faster slider for the cpu overclock option ?
Default is slow as hell and it takes ages to reach 200%.
I use it all the time for mvs roms such as mslug and so...
if I do remember the file to be modified is ui.cpp
Code: [Select]
// add CPU overclocking (cheat only)
slider_index = 0;
if (machine.options().cheat())
for (device_execute_interface &exec : execute_interface_iterator(machine.root_device()))
void *param = (void *)&exec.device();
std::string str = string_format(_("Overclock CPU %1$s"), exec.device().tag());
sliders.push_back(slider_alloc(machine, SLIDER_ID_OVERCLOCK + slider_index++, str.c_str(), 10, 1000, 2000, 1, param));
and replace with
   slider_index = 0;
         sliders.push_back(slider_alloc(machine, SLIDER_ID_OVERCLOCK + slider_index++, str.c_str(), 50, 1000, 2000, 1, param));
I usually make my own builds but I'd like to try yours :wink:
Many thanks, mate.
haynor666
  • retro maniac
« Reply #17 on: July 24, 2017, 05:27:33 am »
Does moving slider with CTRL pressed is not enough? It's really fast for me.
Nodoyuna
« Reply #18 on: July 24, 2017, 06:18:51 am »
Hi
Your version should not have the initial info screens before entering the game, right?
I ask because I keep getting them... Should I activate or deactivate anything in GM?
Thanks in advance
totozero
« Reply #19 on: July 24, 2017, 08:10:46 am »
 :dizzy: .... Ooooops... Really ?
I've been in Mame for years and I didn't even notice that holding ctrl enabled "fast-slinding". Guess you can learn something every day even with dumb questions  ::)
Anyways, thanks for the input.
haynor666
  • retro maniac
« Reply #20 on: July 24, 2017, 08:57:31 am »
Hi
Thanks in advance
Set:
skip_gameinfo             1
in mame.ini
Nodoyuna
« Reply #21 on: July 24, 2017, 11:44:45 am »
Thanks, I'll try that
funkycochise
  • 8 bits generation
« Reply #22 on: July 28, 2017, 01:17:54 am »
didn’t know that slider option through 2 key, above tab key
always thought I was only for volume settings.
for cpu boost, I only used ins key to speed up long boot time
like gradius (before finally ends with a save state for instant boot for that game)
Thank you guys for interesting tips and tricks out there.  :cheers:
also I tested your build haynor : great job !
especially for your precise fixes : will adopt it on the cab.
I’ll keep an older version in second just for kungfum/spartanx
discrete emulation for sounds make them too low and not well balanced.
« Last Edit: July 28, 2017, 01:25:00 am by funkycochise »
markran
  • Last login:October 23, 2025, 10:14:47 pm
« Reply #23 on: August 05, 2017, 11:30:56 pm »
Thanks Haynor666, this looks like the MAME build I need as I'm updating my 10 year-old MAME cab from MAME .120. The cab features WinXP/32, a hacked ATI 9250 and a 25" Wells Gardner 800 x 600 multi-sync CRT.
One question, I have the full (merged) .187 ROM set but the EXTRAS and VIDEOSNAPS folders I could grab are .188. Does anyone think I'll run into issues running them together?
« Last Edit: August 05, 2017, 11:33:03 pm by markran »
haynor666
  • retro maniac
« Reply #24 on: August 06, 2017, 04:04:12 am »
Some extras and videosnaps might need renaming but that's all.
funkycochise
  • 8 bits generation
« Reply #25 on: August 09, 2017, 12:26:01 pm »
Hi haynor666,
while I have a bit of spare time, I tried to compile my own mame build.
I set the build environement as describe in mamdev. Got the current version with git : all went fine and had a shiny mame64.exe, but 188 version.
Then I tried to build a groovy version, as you describe here the patch used.
I have downloaded 187s file and made the folder accessible trough the win32env.bat console.
I then had the patch package tool to the environement.
I tested it with suppression.txt for nag screen as it only touch 2 files.
I run "make" after a while I got my mame64.exe, producing the ini file including the skip_gameinfo entry : all right !
I then tried to build the previous 0186 version, with groovypatch.
when I patched with the d3d9ex.diff and the groovymame diff, I got errors (but it is supposed to be made for this version). Without surprises,
"make" processed failed. I could be more precise with the error if you want.
I just wanted to know witch diff you pass and the order.
Sorry for my dumb questions.
Pierre KFY.
haynor666
  • retro maniac
« Reply #26 on: August 09, 2017, 03:37:08 pm »
No nag was fro 187, my patch also but groovymame patch was originally for 186. You can get no nag 186 but sadly my patch will not work with 186.
funkycochise
  • 8 bits generation
« Reply #27 on: August 10, 2017, 04:06:57 am »
I don't want to go off topic on your topic : I'll open mine, regarding my patching problem, with more details.
http://forum.arcadecontrols.com/index.php/topic,154967.0.html
« Last Edit: August 10, 2017, 05:21:36 am by funkycochise »
haynor666
  • retro maniac
« Reply #28 on: October 30, 2017, 03:44:24 pm »
New version 191 - no new stuff, just to stay inline with official mame.
For now only 32 bit edition: https://mega.nz/#!MgtmUb6S!hVEib8rh_UOTsN0ubixoi-DUveq4hcZ5ynCfb__6sBw
Sky25es
  • Last login:May 06, 2026, 04:43:00 pm
« Reply #29 on: October 30, 2017, 06:47:23 pm »
Wow! Thanks!
 :notworthy:
b4nd1t0
  • Last login:January 29, 2026, 03:45:54 am
    • b4nd1t0's repository
« Reply #30 on: October 30, 2017, 06:55:25 pm »
XP compatible+groovy+suppression?
haynor666
  • retro maniac
« Reply #31 on: October 30, 2017, 06:58:02 pm »
As always - it's XP comp. (should be just like any other version, I didn't tested on my PC yet). Please read first post.
raibol1
  • Last login:December 17, 2024, 09:42:40 am
« Reply #32 on: October 31, 2017, 06:22:10 am »
Hallo,
any chance to get a 191 groovymame 64bit, D3D9ex, supression patch, arcade-only version??
Greets
Rainer
haynor666
  • retro maniac
« Reply #33 on: October 31, 2017, 06:44:52 am »
Before I release other version I have to test this one. It's based on GM 190 patch, still there isn't official GM 191 patch.
NOTE. Haze rewrote SH3 emulation so CV1k games are now much faster. Worth to check if older hardware manage to emulate those games at 100% speed.
« Last Edit: October 31, 2017, 12:28:50 pm by haynor666 »
Josef1975
  • Last login:July 09, 2021, 06:01:15 am
    • MY ARCADE CABINET
« Reply #34 on: November 02, 2017, 05:38:04 am »
Hi haynor666, thanks for your great work!!
« Last Edit: November 19, 2017, 06:16:38 pm by Josef1975 »
haynor666
  • retro maniac
« Reply #35 on: November 02, 2017, 03:05:37 pm »
Updated first post with new links.
Raibol1 this is GM with D3D9ex but not arcade only. It really does not make sense build arcade only release.
« Last Edit: November 02, 2017, 03:09:13 pm by haynor666 »
raibol1
« Reply #36 on: November 02, 2017, 03:41:28 pm »
Thank you very much for this new releases!!!
Arcade only ist not so necessary, in my 2 Arcade cabinets the full version is also great!!
Rainer
michino
  • Last login:March 08, 2018, 10:13:01 am
« Reply #37 on: November 03, 2017, 12:03:29 pm »
Thanks haynor666,
Only one question, we must only replace the Groovymame64.exe? the other archives we leave the old ones?
haynor666
  • retro maniac
« Reply #38 on: November 03, 2017, 02:39:23 pm »
All other files (plugins, artwork) You should get from official mame 191 archive.
Dr.Venom
  • Last login:May 08, 2018, 05:06:54 am
« Reply #39 on: November 04, 2017, 04:43:34 am »
Thanks for posting these builds  :)
Just wondering, would it be useful to post some of these issues (and fixes) at http://mametesters.org/? For example the below seem like issues that may be addressed in the MAME core.
Especially when issue is properly documented and code solution is already included in the description, in my experience they mostly get fixed in the core..
- Bonze Adventure protection fix (no more errors when You die)
- audio fix for Dark Seal and Vapor Trail (now sound does not change it's pitch/speed during attract mode/game)
- proper video timmings in Iron Horse (very usefull for TV/Arcade monitor)
« Last Edit: November 04, 2017, 04:49:21 am by Dr.Venom »
