Author Topic: Ultimarc Aimtrak LightGun with MAMEUI32  (Read 3650 times)
mr_mercury
  • Last login:April 27, 2017, 04:40:19 pm
« on: April 25, 2017, 05:22:35 pm »
Hello All,
I have recently purchased an Ultimarc Aimtrak Lightgun.  I am having trouble getting it to work with MAMEUI32.  Version 0.154.
It works absolutely fine with my Model 2 emulator as it really does just emulate a mouse.  But this is not the case with Mame.
I have followed the steps the best I can by editing the ini file and setting the lightgun flag from 0 to 1 and the same with offscreen reload.  However when I go to general input it will detect movement or trigger clicks or anything.
Is anyone able to provide some advice please?
Thank You.
Titchgamer
Re: Ultimarc Aimtrak LightGun with MAMEUI32
« Reply #1 on: April 25, 2017, 06:57:07 pm »
I dont use Mame UI so may not be right but I dont think you have to do anything in the ini file but it does have a settings menu to enable light guns etc.
Maybe have a look in there?
mr_mercury
« Reply #2 on: April 26, 2017, 03:13:02 am »
Hi Titchgamer,
I did go into the controller mapping tab, there is a lightgun option in there that by default was set to mouse.  However when I set this to lightgun, it still didn't seem to recognise it.
The odd thing is when I load up a rom and press tab to navigatet the menu, I scroll up and down using the light gun, its bizarre.
Maybe I should try and use MAME instead of MAMEUI but from my understanding it is complicated to set up.
Titchgamer
« Reply #3 on: April 26, 2017, 03:56:38 am »
Just to clarify mame is not detecting the AT in the controller config menu is that correct?
The aim trak is detected as a mouse so have you tried setting lightgun as mouse?
mr_mercury
« Reply #4 on: April 26, 2017, 09:03:41 am »
Yeah I did try that too with no joy.
SlyBlueFox
  • Last login:November 29, 2023, 12:11:50 pm
« Reply #5 on: April 26, 2017, 09:11:20 am »
Hi Titchgamer,
If you have not already, go to the Ultimarc website & download the PDF AimTrak setup guide. It gives you step-by-step instructions for regular MAME & is not that difficult to setup (just follow the guide). If you still have any issues, we'll try to help.
mr_mercury
« Reply #6 on: April 27, 2017, 04:41:13 pm »
Hi all,
I managed to get this working.  I just downloaded a newer version of MAMEUI64FX.
Thank you for your help.
