Author Topic: Resolution issue(height) when out outputing to a Jpac  (Read 3472 times)
Gamer4life
  • Last login:June 28, 2024, 01:02:32 am
« on: October 02, 2016, 11:05:58 pm »
I spent some time today trying to get retropie to output a good height to my monitor. I started with a clean install and dropped tmnt in my mame folder. I made sure that everything work fine on my tv before moving it over to my cab.
Before I moved it over to my cab I modified the boot config to:
hdmi_cvt=320 240 60 1
hdmi_group=2
hdmi_mode=87
Everthing works fine, but my image is cut off at the top by a handful of pixels. In game and in retropie(see pic) I tried handful of things but I still cant get a full image. I am using a 25" k7000 with a hdmi to vga to the Pi. Any help would be appreciated.
Gamer4life
Re: Resolution issue(height) when out outputing to a Jpac
« Reply #1 on: October 02, 2016, 11:36:38 pm »
Right after I posted this I found Floobs video on adjusting the border setting in the mame.cfg file that did the trick. Is there any other ways to go about it?
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #2 on: October 06, 2016, 09:01:31 pm »
There are overscan adjustments in mame4all as well as the RPi's boot configuration:
http://elinux.org/RPiconfig
Adjust both to the needs of your particular monitor.
