Author Topic: Extending a ground wire from MiniPac daisy chain?  (Read 1969 times)
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
« on: September 19, 2016, 11:09:53 am »
I can't figure out what I'm doing wrong. I need to extend a ground connection to my NovaGemCDRs on my coin door. I got the wire to the 'NO' working by butt splicing (just using the actual ground daisy chain to test). Now I need to extend a ground wire. Here's the ground daisy chain in question:
I figured I could just get some female and male disconnects and join them that way. I have the male disconnects connected to the daisy chain, and then a new female disconnect on the NovaGem. No go. Anyone have an idea of what's going wrong or what I need to do? The ground is just not reaching the button when I extend using a male/female disconnect.
  • Last login:Today at 05:31:13 am
Re: Extending a ground wire from MiniPac daisy chain?
« Reply #1 on: September 19, 2016, 11:37:27 am »
Check for end-to-end continuity (<2 ohms) on your male-to-female ground extension using a multimeter.
If you don't have continuity, try to:
- Recrimp the QDs
- Replace the QDs (make sure you crimp onto stripped wire, not just insulation   ::) )
If you do have continuity, check the markings on the microswitch to ensure you are on the COM and NO terminals.
If it still doesn't work, touch a piece of wire from the ground wire extension to the signal wire extension to see if the problem is a bad microswitch.
Guywiththegun
« Reply #2 on: September 19, 2016, 12:34:03 pm »
Thanks. So my strategy, in theory, should be working? I figured I might be doing something wrong where the connection is skipping the disconnect or something. I'll test with the multi-meter when I get home.
« Reply #3 on: September 19, 2016, 01:31:13 pm »
Yes.
One other possibility to check is that you could have a bad connection in your pre-fab daisy-chain -- it's rare, but it has happened before.
You can narrow that down using the "divide and conquer" troubleshooting technique.
If the ground connection at the microswitch is point A and the farthest-away connector in the daisy-chain is point Z, check for continuity from A to Z.
If you don't have continuity, check from A to L.
- If it is good, the problem is somewhere between L and Z.
- If it is bad, the problem is somewhere between A and L.
Keep dividing the circuit in half until you narrow down exactly where the problem is.   ;D
Guywiththegun
« Reply #4 on: September 19, 2016, 08:26:58 pm »
Well I got these working after verifying with the multi-meter and now I'm finding they don't stay connected on the switch. Think something's going on with the switches or something.
