Author Topic: Daytona USA 2 Cab Conversion  (Read 31293 times)
terminator2k2
  • Last login:February 10, 2025, 05:35:27 pm
Re: Daytona USA 2 Cab Conversion
« Reply #40 on: August 19, 2017, 05:15:31 pm »
Well I decided to convert my mame machine into a dedicated OutRun 2 SP Arcade machine , using Arcade Components.....
So the search began for a chihiro Type 3 , which I got with a power supply and a I/O Board...
when I tried testing the system, the I/O Board was faulty...So I got one off Mo @ Videotronics....
I got a Compact Flash Card and a IDE to compact flash adapter from Ebay and put Outrun 2 SP on there....
I updated the firmware of the chihiro using an update from DarkSoft and netbooted it to the Chihiro....This allowed any compact flash to work on the chihiro...
I got a Zero Pic chip off Terry (BBZ149)
So I ordered a load of connectors from RS:
I then made up the complete loom for Outrun 2 using a online manual...
At this point all was up and running using my model 2 dash which is now owned by Rich....
I got a Model 3 Dash off Ian....Cheers mate....I would love to have seen some of the folks faces when we were stripping the thing in the back of my van lol on a busy Saturday dinner time on a very busy car park lol
Just testing a few things in the cab:
[DIV]
[/DIV][DIV]
Ive since tidied up the cabling and got a chihiro power extension and a midi Drive Board...
I got a Ferrari centre cap and Bolts and a vr sticker off muddy.....
Well today I connected up the Midi Drive board and filmed it live and its Alive.....
couple of videos
! No longer available
I got the Ferrari emblem the wrong way up lol...more like a donkey haha
So that's it for now....Outrun 2 SP Running in a Daytona USA 2 Cab....
« Last Edit: August 19, 2017, 05:18:46 pm by terminator2k2 »
terminator2k2
« Reply #41 on: August 19, 2017, 05:19:46 pm »
Just picked up my transformer off Ian, cheers mate.[DIV]
just a size comparison lol:
terminator2k2
« Reply #42 on: August 19, 2017, 05:21:39 pm »
well just a small update.....ive been doing the battery backup mod as done by a few members on here....
pictures not the best.....This will be mounted on the rear of the cab in the empty space....
terminator2k2
« Reply #43 on: August 19, 2017, 05:23:06 pm »
ive just added these lol....overkill???
well at least i know my battery is working.....the original wouldnt keep the game and settings as soon as i powered off and back on again......
terminator2k2
« Reply #44 on: August 19, 2017, 05:24:55 pm »
I got some end plates for the foot plate , so decided to put some ribbed rubber matting on there.....ive seen it done like this on a few cabs , but cant remember where haha
I couldnt find the coach bolts to fit the foot plate, but arcade world sell these which do the trick perfectly....just need to cut them down....
terminator2k2
« Reply #45 on: August 19, 2017, 05:26:47 pm »
got my naomi 2 today to try out  pi net booter and card emu.....works a treat
first time i played it with proper ffb....whooooo feedback when you go over the rumble strips
« Last Edit: August 19, 2017, 05:32:58 pm by terminator2k2 »
terminator2k2
« Reply #46 on: August 19, 2017, 05:27:44 pm »
Well i got my brother to 3d print a box to house volume control, test, service and credit button
terminator2k2
« Reply #47 on: August 19, 2017, 05:28:52 pm »
ive had the metal part stripped where the pedals are as it was looking quite bad after i put the foot plate in.......plus i had to remove the front end to get the naomi in.....will be re-sprayed
terminator2k2
« Reply #48 on: August 19, 2017, 05:30:55 pm »
After keep having to open up the cab to swap over the vga cable, power cables , i/o board usb cable , drive board cable, audio cables every time i wanted to swap between the chihro and the naomi 2.......I came up with a plan to automate it by just pressing a switch on the back of the cab....
i used a relay board to switch the usb and drive board cables...2 x 30 amp relays for the 3.3v and 5v feeds....and a vga auto switcher to switch the video and audio.....
the relays are switched by wiring the grounds through a on/off switch......and its working great.....
i will be powering down the cab , then switching the relays on or off.....that way there shouldnt be any arcing in the relays by switching them while the naomi power is live.....
DudeRegular
« Reply #49 on: August 31, 2017, 10:04:09 pm »
Nice work man. Very cool stuff.
05SRT4
  • Check out my Pow Pow
« Reply #50 on: August 31, 2017, 10:08:52 pm »
3d printed parts for the win!
Some good hard work with this. Keep it up.
Stormtrooper
  • Last login:August 24, 2019, 02:03:46 am
« Reply #51 on: April 11, 2019, 01:05:24 pm »
Hi
Congrats for your amazing work!!!
Can you please let me know how can I find those seat cushion in yellow or blue for my Daytona 2 twin?
Thank you
