Author Topic: JPAC - How the heck do you troubleshoot?  (Read 2707 times)
Bimmy
  • Last login:November 09, 2025, 07:25:18 pm
« on: September 04, 2015, 06:15:08 pm »
Win7 with the Calamity driver. Using Arcade OSD to switch to 640x480 15k.
When I switch to 15k on a VGA monitor, it's easy to see it worked.
It doesn't look like a 31k problem, right? Looks like resolution switched back to 1024 or something? Why is it purple? How can I troubleshoot in Arcade OSD if I can't see what I'm doing? I've tried remote-ing into it with VNC but VNC's display driver confuses Arcade OSD.
« Last Edit: September 04, 2015, 06:40:30 pm by Bimmy »
Bimmy
Re: JPAC - How the heck do you troubleshoot?
« Reply #1 on: September 04, 2015, 06:55:59 pm »
Update. Same look even at first boot on the bios screen. Do I possibly have a bad JPAC? I should at least get proper color and see what's going on at 31k correct?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #2 on: September 05, 2015, 04:56:22 am »
You ARE supplying it with power via ps2/USB right?
Calamity
  • Moderator
  • Last login:Today at 07:35:09 am
  • Quote me with care
« Reply #3 on: September 05, 2015, 05:10:13 am »
Yeah that's probably the problem.
Steps to create a log:
Bimmy
« Reply #4 on: September 05, 2015, 09:14:00 am »
yes all 3 LEDs are lit solid. In fact they are lit ALWAYS even when not connected to a jamma harness. Is this right?
« Last Edit: September 05, 2015, 09:37:16 am by Bimmy »
