Author Topic: RetroPie with 2x USB controllers and GPIO connections  (Read 4058 times)
camperman73
  • Last login:February 26, 2016, 11:38:31 am
« on: July 31, 2015, 03:54:44 am »
Hi
I am building a Sega Megadrive bartop.
It will be one player, joystick, 6 buttons.
Also, i want to add 2x USB controller for two player games.
I was thinking of plugging the USB controllers into the USB ports, then using the onboard GPIO for the joystick and buttons.
Is this easy to do?
Do i add joystick 1, 2 and 3?
Just wondering as the Joypad 1 will be the same controls as the joystick and buttons.
geeteoh
  • Last login:May 30, 2017, 09:28:59 pm
  • Connecting with the 80s
    • forum.arcadecontrols.com/index.php/topic,146453.0.html
Re: RetroPie with 2x USB controllers and GPIO connections
« Reply #1 on: July 31, 2015, 07:55:36 am »
It depends on the Sega emulator. Can it be configured with the input you want? You'll have to give it a try. Prototype the whole system first. Then design the control panel and cab.  I know that the adv-mane emulator will do this. EmulationStation FE can with some config.
camperman73
« Reply #2 on: July 31, 2015, 08:31:36 am »
Great thanks for that. I will be using EmulationStation from retro Pie.
Weekend of mocking up i guess.
