Author Topic: Adjusting emulator resolution in Hyperlaunch.  (Read 1760 times)
deano71
  • Last login:August 30, 2015, 08:30:15 am
« on: June 17, 2015, 05:25:27 am »
Hi i have a problem with a emulator displaying in full screen. I want to adjust the resolution down in hyperlaunch so it does not launch full screen. Any ideas how to do this?
lamprey
Re: Adjusting emulator resolution in Hyperlaunch.
« Reply #1 on: June 17, 2015, 01:02:18 pm »
It would depend on the emulator. I don't have experience with them all, but they tend to have a command-line parameter for that. If not, then you might need to adjust the emulators config file for the emulator or per game.
deano71
« Reply #2 on: June 17, 2015, 01:21:45 pm »
Hi its Prosystem for Atari. The full screen resolution makes all the colours funny.
  • Last login:May 09, 2026, 10:52:25 am
« Reply #3 on: June 17, 2015, 01:30:07 pm »
Never heard of that one.
lamprey
« Reply #4 on: June 17, 2015, 01:59:58 pm »
From the documentation that comes with ProSystem:
Command Line switches
The following list the command line switches allowed in ProSytem. If loading a rom file on the command line, it must be the last parameter in the list.
-Fullscreen   value
Use value = 1 for fullscreen
Use value = 0 for windowed
You might want to check out MESS (MAME) as it also supports the 7800 and is actively being developed. But, YMMV.
deano71
« Reply #5 on: June 17, 2015, 03:48:56 pm »
Hi, I tried mess and its a mare to set up. Trying to get right bios files etc.
