Author Topic: Remove "Starting" box  (Read 3462 times)
Chappie
  • Last login:February 04, 2023, 07:55:59 am
« on: December 28, 2014, 07:15:59 am »
I am pretty sure this is a Mala input, but I want the square box that pops up that says "Starting" when you select a game to go away or be moved some. Running dual displays and the box partially shows up in my marquee monitor. This box looks just like the "Quit Mala?" box, so that is why I think it is Mala derived.
Chappie
Re: Remove "Starting" box
« Reply #1 on: December 28, 2014, 10:39:37 am »
Semi-solved it (actually better than I had hoped)...in the Mala Options under the GUI tab, select the Game Start/Quit tab. I selected "Use Fullscreen Starting Picture Instead of Starting Window". I did not populate the Horizontal or Vertical fields below it and when I start a game now it gives me a fullscreen neat looking "Get Ready to Play" graphic and that goes quickly away as the game comes up. No small "Starting" box pops up now or left showing in my marquee display.
« Last Edit: December 28, 2014, 10:45:38 am by Chappie »
