Author Topic: US Games Super Duper Casino. plays To fast  (Read 2126 times)
janey
  • Last login:August 06, 2016, 02:36:23 pm
  • I want to build my own MAME / Hyperspin cab
« on: October 05, 2014, 12:05:29 am »
How do i slow down this game ?? Its just loads to fast .
I Held RED button and turn on machine and Nothing. Do I need a keyboard to be plug in the slot ????
lilshawn
  • Last login:June 07, 2026, 05:26:02 pm
Re: US Games Super Duper Casino. plays To fast
« Reply #1 on: October 07, 2014, 11:49:01 am »
You could pull out a ROM and have it NOT load. Not sure what you are getting at here. is it supposed to load slow? Did you need to do something during boot? IE the hold the red button to do a ROM check?...you can just hold the button and power it on, it should still register.
hope this helps somewhat.
janey
« Reply #2 on: October 12, 2014, 10:47:23 pm »
The Games  and trivia's it self loads to fast ,   Eveything goes to fast , cant read  the questions ,
I;ll make a quickvid.
lilshawn
« Reply #3 on: October 13, 2014, 11:44:54 am »
Check the RTC time. make sure it's set to the correct time and holds after you power off... you may need to replace it (U1 in marker in your photo) if the system won't hold a time.
while not knowing specifically this machine, lot's of games like this scan the RTC chip for game timer data. if it's always zero (DEAD), your counter won't work properly (IE the system checks the seconds, sees 0 for the data and then goes ahead and displays the question. the game then continuously checks for the appropriate amount of time to go by...lazy programmers often program 10 seconds to go by because lazy programmers will queuey the seconds bits of the RTC chip for it to be the same data again to reduce the amount of code that needs to be written....but it already is.)
the solution to this lazyness (why still being lazy) is to do whatever the bit data is -1 (which coincidentally is why alarm clock snooze is 9 minutes) if the RTC failed though the timer would never change.
RTC chips when they fail, default the clock to OFF (to save power during shipping after it's manufactured). when the clock is set, there is a bit that gets set that makes the clock begin counting. in this off state, the data can still be read, but will not change. (seconds won't tick by)
TL;DR - check your system time is properly set and holds the correct time when powered off.
janey
I figured out.. I feel So Dumb....
« Reply #4 on: October 24, 2014, 07:05:20 pm »
I,m so stupid.... LOLO.
 I fig it out.. It was the intro..
 I had to insert coin and then i was able to play it normally.
 Plus i found the book manual inside cab..
