Author Topic: Need help something wrong is going on with monitor. lines running across screen  (Read 1631 times)
pathfndr
  • Last login:September 05, 2014, 11:20:39 pm
Chassis is Wiei-ya 429h, something needs replacing but don't see anything damaged. Thanks for any advice.
grantspain
screen volts is too high
contrast is too high
pathfndr
Thanks for the response but that not it, I turn both the flyback knob and the one on the remote and I'm getting either dark or too bright with just a little movement. Both knobs I use to have full control where I could move them alot to change change, now just a couple clicks and they go to the extreme. I tried moving the B+ voltage a little to up and down does nothing. Letters are bleeding a little to.
