Author Topic: wiring coin mech, using laptop  (Read 2917 times)
16bitcatholic
  • Last login:June 02, 2014, 09:46:53 pm
« on: April 11, 2014, 07:09:34 am »
Ok, so my mame cab is running courtesy of a laptop. Not my first choice, but it was just collecting dust and has a dual core processor.
I'm trying to wire a coin acceptor. It's a standard coin acceptor that requires an12v power supply, and most tutorials say to use the PSU. In this instance, what can I use to power this device?
every time I have a question, this board is so kind in their answers, so I do thank you in advance!
  • Online Online
  • Last login:Today at 07:01:39 am
Re: wiring coin mech, using laptop
« Reply #1 on: April 11, 2014, 08:04:20 am »
You may need to use a wall wart -- not sure about the current draw spec, though.   :dunno
Don't forget to use a zener diode to protect your encoder.   ;D
« Last Edit: April 11, 2014, 08:13:58 am by PL1 »
16bitcatholic
« Reply #2 on: April 11, 2014, 08:49:08 am »
Does the wall wart you linked to allow me yo wire in a 12v wire, or do I need to take apart an ac adapter wire and connect it that way?
I'm assuming the diode just connects between the ground and the wire that connects to the ipac4.
  • Online Online
« Reply #3 on: April 11, 2014, 11:43:31 am »
The easy way is to just cut off the circular power connector and connect the 12v and ground wires it to the coin mech.
There are plenty of related threads with information and wiring diagrams that show how to wire the mech, including the zener diode -- search is your friend.
P.S. Would you (or anyone else with a coin acceptor) mind posting a few good photos of your coin mech that I can use for the wiki -- it's easier than getting permission to use copyrighted photos from a website.   ;D
A neutral background and photo angles similar to these would be great.
