Author Topic: SOLVED: Wiring Questions (Joystick & LEDWiz)  (Read 3238 times)
SgtSlaughter
  • Last login:March 02, 2021, 10:38:50 am
« on: January 06, 2014, 11:22:45 am »
So the hardware I have is:
U360 Joystick
11 - LEDWiz Electric Ice Pushbuttons with RGB-Drive II pushbutton Lighting module
So I've been reading a lot of the forums for wiring up the LEDWiz, but I'm getting myself a little confused, and just want to confirm my thoughts before I blow something up.  I've already read http://forum.arcadecontrols.com/index.php/topic,87419.0.html which is what I'm going off.  Here is what I've wired up so far:
I want to have all 11 buttons to have full RGB capibility, but I don't mind pairing them up (as I know there is not enough outputs to do full RGB to each button).
LEDWiz Questions:
ANSWERED 1) If I'm using the red wire from the PC power supply molex connector, to connect to my black wires to a Terminal Block (which are daisy chained together) from the RGB-Drive LEDs (5V), do I need to use an inline fuse?
ANSWERED 1a) If I do need an inline fuse, can I just use 1 that goes directly between the 5V Molex from the PC and a terminal block of my LEDs, or do I need  do I have to an inline fuse for each RGB LED?
ANSWERED 1b) If I need an inline fuse, what size would I need?  I assume 660mA (if I need 1), or 60mA if I need one for each LED?, but if I can't find the exact size should I round larger, or round down?
ANSWERED 2) Can I use the black wire from the PC Molex connector to plug into the LEDWiz Ground?
ANSWERED 3) Do I need to use the Bank Voltage Select terminals on the LEDWiz (assuming that I'm getting my 5V power from the PC Molex connector)?
ANSWERED 3a) If so, is it a problem when I have an RGB LED going across both banks (ie outputs 7,8,9)?
Joystick Questions:
ANSWERED 1) For the Quick connects (or disconnects), I haven't used these before, do you just stick the wire in and crimp them?  I've tried this and it doesn't seem to make a very tight fitting (either that or I don't have the correct tool), or do you take the insert out, crimp & solder?
« Last Edit: January 08, 2014, 11:21:06 am by SgtSlaughter »
SgtSlaughter
Re: Wiring Questions (Joystick & LEDWiz)
« Reply #1 on: January 07, 2014, 03:48:21 pm »
I removed some questions that I was able to answer myself... don't feel intimidated guys, you don't have to have all the answers, any will help!  heh.
roknrol
  • Last login:October 30, 2025, 03:51:17 pm
« Reply #2 on: January 07, 2014, 06:05:23 pm »
I'll take a stab at your QDC question: Stranded wire (not solid) is going to work the best. Most folks seem to use 18-22 ga. for their wire-up jobs. Just strip the wire 1/8", insert it, and use a crimper to complete the connection. Mind you, a ratcheting crimper is highly recommended. I got mine for ... mmm ... $6 at Harbor Freight.
SgtSlaughter
« Reply #3 on: January 07, 2014, 06:57:51 pm »
Ahh good to know.  I figured that may have been the case.  Thanks for the info!
RandyT
  • Last login:Yesterday at 12:58:21 pm
    • GroovyGameGear.com
« Reply #4 on: January 07, 2014, 09:06:36 pm »
One fuse on the 5v line that is distributed to the LED's is enough.
Ultimately, that is up to you to decide.  But you shouldn't need more than 1 amp.
Yes.
I would.  It's a small extra step and worth doing.
No.  If the voltage is the same for the rest of that bank, connect 5v to that Bank Voltage Select terminal as well.
SgtSlaughter
« Reply #5 on: January 07, 2014, 11:08:28 pm »
There's the man...  Heh I was hoping someone else would respond so I didn't have to bug you Randy as I'm sure your always answering questions like this.
In terms of the Bank Select, I'm confused on what they do and how I would wire it.  I assume I would just feed the +5V into both of them as well?
Thanks again Randy, your products are awesome!
RandyT
« Reply #6 on: January 08, 2014, 04:55:51 am »
No problem...just connect your +5v line to the Bank Voltage Select terminals and remember that you can only use 5v devices on those banks.  If you need to run devices of a different voltage, you will need to use a different bank of outputs.
SgtSlaughter
« Reply #7 on: January 08, 2014, 11:20:15 am »
Good to know.  Thanks again for the help!
Bambam1963
  • Last login:March 09, 2024, 11:46:07 pm
  • I love this stuff man!-
Re: SOLVED: Wiring Questions (Joystick & LEDWiz)
« Reply #8 on: January 12, 2014, 10:25:47 pm »
So does that mean I could wire up a red 12 vdc police light to the top of my arcade that will activate when someone gets a highscore?  How would you wire that?  The kids would love that :-)
I am an oldie, who used to troll here years ago.  Now I am back to tweak my machine and help a friend build his.
