Author Topic: 15Khz through GBS-8100  (Read 1872 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: December 29, 2013, 11:50:53 am »
I just got my GBS-8100 and I'm having trouble getting the frequency to match on my K-7000 chassis
The cabinet has a CAPCOM I/O and I'm routing the video signal to its VGA port so I'm using the VGA-OUT on the GBS-8100, IM not seeing any information on switching the device to 15Khz only output-- I thought this was supposed to be a video converter but it seems to be just passing through the VGA signal
« Last Edit: December 29, 2013, 12:02:09 pm by bimm25e »
bimm25e
Re: 15Khz through GBS-8100
« Reply #1 on: December 29, 2013, 02:12:16 pm »
answered  my own question - the VGA out is simply a passthrough, by making a female VGA lead using pins 1,2,3,5,13,14 (r,g,b,Gnd,Sync-bridged)I was able to use the VGA lead with the 15Khz RGB standard going through it.
anyone know how to make these things save settings after they lose power?  It would really suck if I had to recalibrate it every time I reboot the PC (which is supplying the +5VDC to the unit)
