Author Topic: Wiring RGB LED Illumination Kit with PAC Drive  (Read 1797 times)
Soxmls35
  • Newbie
  • Last login:October 22, 2013, 05:52:26 pm
« on: October 22, 2013, 05:12:24 pm »
I have a RGB LED Illumination Kit for my U-Trak.   I am attempting to wire the Illumination Kit to my PAC Drive.  The Illumination kit has 5 wires.  A 5v Yellow wire. Three colored wires  Red, Blue, and Green.  Then a ground wire.   As I understand it I wire the 5v wire to the + connection on my PAC Drive.  Then the Red Blue and Green wires to the 1 2 and 3 spots.  I am not sure what I am supose to do with the ground wire.
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
Re: Wiring RGB LED Illumination Kit with PAC Drive
« Reply #1 on: November 04, 2015, 05:35:18 pm »
Sorry to dig old thread up but I have the same question.
lamprey
« Reply #2 on: November 04, 2015, 06:34:18 pm »
Maybe someone will know for certain what to do with the black ground, but I'm not sure that you need to do anything with it.
Assuming that the yellow is the +5vDC Common Anode, then the R, G & B wires are the -Cathodes (Ground). So, all you should need to complete the circuit are the Yellow and the RGB wires.
deezdrama
« Reply #3 on: November 04, 2015, 08:58:51 pm »
Thats what I was thinking. Not sure what the ground is for then.
Also ultimarcs site says the rgb kit will plug directly into the pacdrive but the rgb has a female 4 pin connector and the pacdrive uses screwdowns. Im going to just snip off the connector but wondered why the site says a direct hookup.
