Author Topic: Game stuck in a Start UP loop?  (Read 2845 times)
Fallen_Veteran
  • Last login:February 06, 2014, 10:06:38 pm
« on: April 21, 2013, 11:42:25 pm »
I am not sure what is causing this to happen but upon turning the machine ON, it will go through its normal start up and find the Hard Drive, everything checks out OK, OK, OK, etc and then rather than starting up it makes this sound like its rebooting and goes through the process again and gets stuck in this cycle. If I turn the machine on/off a couple times it resolves itself but there has to be a better way?
Golden Tee Fore is the machine
AAirhart
  • Last login:October 20, 2018, 09:54:24 pm
Re: Game stuck in a Start UP loop?
« Reply #1 on: April 22, 2013, 12:04:46 am »
Power supply might be starting to fail
ed12
« Reply #2 on: April 22, 2013, 05:58:13 am »
hard-drive's mbr is shot from the fall
ed
ch05yn1
  • Newbie
  • Last login:January 11, 2015, 01:16:18 pm
« Reply #3 on: December 24, 2014, 12:00:14 am »
How did you resolve this issue?
lilshawn
  • Last login:August 27, 2026, 06:39:50 pm
« Reply #4 on: January 01, 2015, 11:20:06 am »
replacing or re-imaging a new drive is usually the fix for this issue. the drives are nearing 10 years old, and they don't make them like they used to.
check ebay for replacement drives.
