Author Topic: rowe ami cd 100 problem  (Read 3032 times)
tipiakP
  • Last login:March 30, 2013, 01:36:35 pm
  • jukebox addict
« on: March 23, 2013, 05:13:19 pm »
Hello,I am new to this forum,I am living in france,I have a rowe ami cd 100,and I have a problem with it.The arm take a cd and replace it in the magazine over and over,I have already checked the switches on the mechanism and they are OK,it seems to be "the fault" of the mechanism control computer,I have "looked"for dry joints with no success,I actually wonder about the U10 ic who is controlling the triac......I really dont know , I am lost could someone help me ? thanks....
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe ami cd 100 problem
« Reply #1 on: March 26, 2013, 06:01:02 am »
Hello tipiakP,
If you wish to have your boards and laser tested/repaired, please send me a PM or email me on alan-hood@datex.co.uk.
Regards
Alan
Alan Hood
ami-man
UK
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« Reply #2 on: March 27, 2013, 11:20:17 pm »
Try going over the connections. Pull the spade connectors off the switches and clean them with a small wire brush. Also pull all the plugs out of the mech-controller and plug them back in. It could just be a connection issue.
ami-man
« Reply #3 on: March 28, 2013, 05:25:02 am »
Hello Karetaker,
Yes the issue could be connection problems, dry joints (cold joints USA) on the connection pins. Going over the connections (resoldering) is ok if the person can correctly solder, but it wants to be to the connection pins only if anyone then starts going over any of the component connections it cost an hefty sum to correct this practice.
From a technicians point of view you are best to leave it alone to get a cheaper repair should it have to go into a workshop for repair.
Re cleaning connections the best way is to use a pencil rubber (eraser) for any tracks using wipers and other connections such as the pins above use one of those fibre glass pencil (used on watch battery connections etc).
Regards
Alan
Alan Hood
ami-man
UK
tipiakP
  • jukebox addict
« Reply #4 on: March 30, 2013, 01:14:58 pm »
Thanks for your answers all !! I will check AGAIN the connections........I also have another question:when did "the red led"HOME and LINK must or should lit ??? Because "they seems" to NEVER lit at all !!! So if you can tell me..........MANY THANKS
ami-man
« Reply #5 on: April 02, 2013, 05:45:59 am »
Hello tipiakP,
The Home led lights at possition 99 and the index led pulses as it counts the teeth from number 99 (it has a hole in the drive gear at this position).
If both the index & home leds do not flash there will be a fault on the Mechanism Control Unit or the opto switch.
Regards
Alan
Alan Hood
ami-man
UK
Karetaker
« Reply #6 on: April 02, 2013, 02:11:45 pm »
Hello Karetaker,
Regards
Alan
Alan Hood
ami-man
UK
I agree when it comes to soldering. But, it doesn't take a technician to pull plugs off and re-seat them. As long as he cleans the switch terminals with the power off it will be fine.
DLinkOZ
  • Last login:March 22, 2017, 08:12:46 am
    • The DaveCade
« Reply #7 on: April 06, 2013, 09:06:31 pm »
One of mine is doing the same - grabs a disc, spins for a second, then puts back into the carousel.  Repeat then gives up.  I'll pull it back out and go over all the connections and see if that helps, per this thread.
jdemarti
  • Last login:May 31, 2022, 10:57:25 am
« Reply #8 on: April 07, 2013, 10:09:23 am »
Hello DLinkOZ
Your situation may be a little different. From what you describe it looks like you may need to just replace the optic assembly in your cd player.
DLinkOZ
    • The DaveCade
« Reply #9 on: April 07, 2013, 05:49:44 pm »
Exactly, everything else looks solid.
