Author Topic: CPWizard Setup or Winipac Setup?  (Read 4450 times)
maffewl
  • Last login:June 05, 2020, 03:11:44 pm
« on: February 17, 2013, 03:56:20 pm »
Hey everyone... Just looking for something to show what each button does at game start, or pause, or whatever...
I just set up my layout and labels in CPWizard, but don't know what to do from there, and how to set it up with MALA?  Is there a how-to somewhere?
Also, thought I read somewhere that you could do the same with the Winipac software.  I also have my layout and keys mapped correctly in it as well if there is a way to do the same thing without using CPWizard.
Any help?
maffewl
Re: CPWizard Setup or Winipac Setup?
« Reply #1 on: February 18, 2013, 12:39:40 pm »
Anything?
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #2 on: February 18, 2013, 04:32:40 pm »
are you asking about showing the original control panel (theres a dedicated window box in the layout manager for that you just need the pics) for each machine or which buttons on your cab does what on yours? if its the second i`m going to be attempting it soon with a pic of my control panel in my layout and figuring out how to sort out the variables for showing different text over the buttons for each game, saw one post which showed what i was planning but they didnt explain anything for the computer illiterate might as well have been speaking klingon for all my computer knowledge, can do it for other emulators when i finally hear which are the recommended ones as the buttons are fixed, but mame games have different controls so i need to figure it out too, gonna bookmark this incase you get an answer i can use too :)
Hit something hard enough it should work, if it dont the result can always be called art :)
maffewl
« Reply #3 on: February 22, 2013, 02:51:20 pm »
Appreciate the response CpCaveman... I just gave up on the program.  I couldn't seem to get it to do what I was looking for.  I just wanted it to show the labels for the buttons before the game started.  I.e., start a game such as Mortal Kombat, it would show what buttons punch, kick, block, etc. then load the game.  It would have been nice if I hit pause and it would have shown the CP again.  However, I kept getting Microsoft .Net framework problems and it (CPWizard) would take forever to load with only the "Show CP" buttons checked, so I just ditched it.  Might try Johnny5 and see if it's any better.
I thought I read somewhere that Ultimarc's Winipac program would do this as well?  That would be nice because I already have my CP layed out in it.  Any thoughts?
bmanbdaman
  • Last login:May 09, 2018, 10:03:23 pm
« Reply #4 on: March 24, 2013, 01:09:00 am »
I use Johnny5 and it rocks on the cpanel. My X-Arcade pic and buttons show up for MAME and I even use it for emulators by adding my custom layouts and button info into controls.ini.
Johnny5.bat
Code: [Select]
set a=1
set lof=console
REM Atari
if /i "%1 %2" EQU "atari 2600" set a=a2600
if /i "%1 %2" EQU "atari 5200" set a=a5200
if /i "%1 %2" EQU "atari 7800" set a=a7800
if /i "%1 %2" EQU "atari lynx" set a=alynx
if /i "%1 %2" EQU "atari jaguar" set a=ajaguar
REM Nintendo
if /i "%2" EQU "nes" set a=ninnes
if /i "%2" EQU "snes" set a=ninsnes
if /i "%2" EQU "gb" set a=ningb
if /i "%2" EQU "vb" set a=ninvb
if /i "%3" EQU "ds" set a=ningbds
if /i "%2" EQU "gbc" set a=ningbc
if /i "%2" EQU "gba" set a=ningba
if /i "%2" EQU "64" set a=nin64
REM Other
if /i "%1" EQU "colecovision" set a=%1
if /i "%2" EQU "wonderswan" set a=%2
if /i "%2" EQU "intellivision" set a=%2
if /i "%1" EQU "watara" set a=%1
if /i "%1" EQU "nec" set a=pcengine
REM NeoGeo
if /i "%2" EQU "cd" set a=neogeocd
if /i "%2" EQU "pocket" set a=ngpocket
REM Sega
if /i "%2" EQU "genesis/32x" set a=segagen
if /i "%2" EQU "genesis/md" set a=segagen
if /i "%2" EQU "master" set a=segams
if /i "%2" EQU "gamegear" set a=segagg
if /i "%2" EQU "sg1000" set a=segams
if exist layouts\%a%.lof set lof=%a%
johnny5 %a% -lof %lof%.lof
controls.ini addon
Code: [Select]
[neogeocd]
gamename=Emulator: Nebula
numPlayers=2
alternating=0
mirrored=0
tilt=0
cocktail=0
usesService=0
miscDetails= Shin Nihon Kikaku (SNK) first ventured into the arcade market in 1989 and was successful with its unique 2D arcade machine.  This arcade version was known as MVS, or Multi-Video Output and allowed 1 of 6 games to be loaded at any time.  The Neo Geo AES (Advanced Entertainment System) was a home version of the Neo Geo MVS and played the exact same games as the ones in the arcades. The major weakness of the Neo Geo AES was the high price tag on the cartridges.  Most games sold for about $200!  The console itself was also fairly expensive, retailing at $650.  Its arcade-style joystick and excellent arcade ports made it a very attractive console.
P1Controls=8-way Joystick+joy8way
P1NumButtons=10
P1_BUTTON1=A
P1_BUTTON2=B
P1_BUTTON3=C
P1_BUTTON4=D
P1_BUTTON9=Start
P1_JOYSTICK_DOWN=Down
P1_JOYSTICK_UP=Up
P1_JOYSTICK_LEFT=Left
P1_JOYSTICK_RIGHT=Right
P2NumButtons=10
P2Controls=8-way Joystick+joy8way
P2_BUTTON1=A
P2_BUTTON2=B
P2_BUTTON3=C
P2_BUTTON4=D
P2_BUTTON10=Exit
P2_JOYSTICK_DOWN=Down
P2_JOYSTICK_UP=Up
P2_JOYSTICK_LEFT=Left
P2_JOYSTICK_RIGHT=Right
« Last Edit: March 24, 2013, 01:11:48 am by bmanbdaman »
