Author Topic: cannot get resolutions lower than 400x  (Read 2580 times)
churkus
  • Last login:April 29, 2016, 01:51:33 pm
« on: January 05, 2013, 07:09:09 pm »
Hi all,
firstly I am using an ATI X1300/X1550 (not too sure which one it is, that is how it is reported as in Windows and this was some OEM card lying in my bros "junk" box!).
I had previously just got round to installing soft15khz on Windows 7x64 and was able to sucessfully get a picture on my Sony KV29F1U Scart TV using a VGA to Scart cable. However it was showing no additional resolutions which from reading I think is a problem witn Windows 7.
So I had some time so I decided to go the whole hog and install Windows XP 64 bit, Calamitys CRT Emudriver 9.3. ALl installed fine, so I proceeded to run VMMaker, and got I think 109 modelines, but all the resolutions I want seem to be there I guess.
However, using ArcadeOSD, when I select a resolution lower than 400x, I get a black screen, and on some of them the PC reboots!. The same sub 400x resolutions will work when I connect back to my LCD monitor.
Is this a problem with my card not having the lower dotclock do you think or is it driver related?.
Any help appreciated.
churkus
Re: cannot get resolutions lower than 400x
« Reply #1 on: January 07, 2013, 01:23:35 pm »
well, luckily for me, me bro also had some other ati card and turns out its an x300 from some old dell. swapped it in and all resolutions working :applaud: :applaud:
so I guess the x1300/x1550 is definately one of the limited cards.
Thanks Calamity for this great stuff  :)
Calamity
  • Moderator
  • Last login:Today at 08:27:31 am
  • Quote me with care
« Reply #2 on: January 07, 2013, 02:49:51 pm »
Hi churkus,
Yes, sorry for being late, the X series, starting from some level (probably X800) have this problem with low dotclocks. The X300 on the other hand works great.
Steps to create a log:
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: January 07, 2013, 05:58:55 pm »
My X800 worked tits with Soft15.
-Banned-
churkus
« Reply #4 on: January 08, 2013, 04:39:12 am »
lol it worked "tits"?. Is that a double negative or a double positive? :applaud:
