Author Topic: Can someone please check my illustrator file?  (Read 1479 times)
ddr
  • Last login:June 11, 2020, 08:20:09 pm
« on: December 06, 2012, 07:36:02 pm »
Hi Folks,
This is my first time trying Adobe Illustrator (or any other graphics system).  Can someone please double check this for me please?  My monitor is 14.5" wide, and 12" tall.  The glass is 21.5" tall and 24" wide.
If you see anything that you think will not print nicely (I will be uploading it to gameongraphix.com) please let me know.
Thanks,
Dan
Hitek
  • Last login:September 29, 2013, 07:20:25 pm
Re: Can someone please check my illustrator file?
« Reply #1 on: December 09, 2012, 07:32:50 pm »
The sizing looks fine to me. I would move the Galaga logo up just a bit, and maybe move the space invaders a bit farther from the inside edge, and it looks like the "Midway" got lost from your Ms. Pac-Man logo, and there is a little diagonal white mark on the right side of it.
ddr
« Reply #2 on: December 11, 2012, 06:57:28 pm »
Thanks Hitek, I appreciate you looking at it.  Order is in!
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #3 on: December 11, 2012, 08:34:47 pm »
DDR,
Sorry to tell you but your illustrator file is off. The height for one is NOT 21.5" but rather 22".
I'm and EXPERT in Illustrator. I've used it professionally nearly everyday for the last 18 years...
I took the liberty of rebuilding your file. See attached. fixed the alignment of both the monitor cutout and both inner and outer dimensions as indicated and cleaned up the artwork including the artifacts around Ms Pac-Man. Resized and moved a couple of other graphics including Pac-Man, which was not centered.
I'd strongly suggest using my file even if you decide to move the graphics around to your own liking.
[EDIT: my zip file won't load. It's 2.2 mgs. Send me a private message with your email and I'll send it to you]
See here for other arcade/character artwork I created for my own cabinet.
You're welcome to use any of it if you'd like (vector format for Illustrator):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
« Last Edit: December 11, 2012, 08:45:49 pm by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
Frontend Video Intro: http://bit.ly/1P9HPDN
