Author Topic: Problems with DOS MAME and ArcadeOS...  (Read 1428 times)
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« on: October 10, 2003, 10:26:10 pm »
Okay, I'm going crazy.
I'm working on a computer that will be in a bartop.  I'm using DMAMEPP 074b (DOS Mame for i686) and the latest ArcadeOS.  About 75% of the time, I'm getting a black screen when I attempt to start the ROM.  The other 25% it works fine.
It passes the command line fine.  The command line goes away and I simply get a blank black screen.  The only way to exit this is to power the computer off.  Escape doesn't work and even Ctrl+Alt+Del doesn't work.
Hopefully someone will have some input.
Thanks!!
« Last Edit: October 10, 2003, 10:27:22 pm by gndprx »
menace
Re:Problems with DOS MAME and ArcadeOS...
« Reply #1 on: October 11, 2003, 11:07:51 am »
Maybe back up a version of dmame?  I went from .72 to .69 and it solved some bugs I was having--just a thought.
SirPeale
  • Green Mountain Man
« Reply #2 on: October 11, 2003, 07:09:52 pm »
Does it do it with the same ROM 75% of the time, or is that figure for 75% of the time random ROMs give you the blank?
gndprx
  • nope...
« Reply #3 on: October 11, 2003, 07:38:21 pm »
Random ROM's
I actually had to drop out of ArcadeOS today to test with Ms. Pacman.  Ran fine once I left the FE.  Yet gave me a blank screen when I tried to launch it from within the FE.
But just last night, it launched the same ROM just fine.
I can't seem to figure out what is going on.
I'll try an older MAME once I can  burn it off to CD to load it up.
