Author Topic: Custom Monitor Bezel  (Read 3978 times)
mytymaus007
« on: June 24, 2012, 09:23:11 pm »
Im looking for a custom size monitor bezel for 20 inch LCD 4:3 size not wide screen
iscariot
  • Last login:April 02, 2025, 12:44:33 am
Re: Custom Monitor Bezel
« Reply #1 on: June 29, 2012, 07:31:55 am »
I think there's a thread here on how to make your own bezel.  That one works and looks great.
capsule
  • Last login:June 22, 2013, 12:05:13 pm
    • caps:arcade
« Reply #2 on: June 30, 2012, 11:34:36 am »
tsaylor
  • Last login:April 20, 2019, 05:16:20 pm
« Reply #3 on: June 30, 2012, 12:07:19 pm »
I used the same monitor type.  But since monitors are flat these days I ended up just making a flat bezel from black poster board.  I cut the opening using an x-acto knife and a straight edge.  But I also needed some wood trim on the sides just to hold it down flat (as the poster board wasn't so thick so it wanted to buckle a little).
I had looked at those threads on making your own, which looked great, but which also had a curve to match CRT's.  For an LCD you won't want it to curve where it meets the monitor.
mytymaus007
« Reply #4 on: June 30, 2012, 06:43:23 pm »
Any pics?
