Author Topic: Do I need to prime my control panel?  (Read 2294 times)
Los Abrazos Rotos
« on: April 16, 2012, 03:05:22 am »
I've done a bit of work on my control panel, basically it had pre cut holes so I have plated behind and used auto filler. It looks good & is strong but i was wondering - is it necessary to prime before I apply the control panel overlay?  I wonder how the adhesive would stick to the auto filler...  Any thoughts?
cheers  :cheers:
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Do I need to prime my control panel?
« Reply #1 on: April 16, 2012, 06:44:13 am »
It's not necessary if you're using an adhesive.  I would scuff it up with some 150 grit.  Are you using an overlay that has adhesive on it or are you using a contact cement/3m spray?
Well Fed Games
  • Delicious!
« Reply #2 on: April 16, 2012, 08:30:35 am »
I primed mine, if nothing else to give a little more uniformity to the texture & color under the overlay.
Los Abrazos Rotos
« Reply #3 on: April 16, 2012, 10:27:22 am »
Its adhesive backed, thanks for the advice  :applaud:
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: April 17, 2012, 11:54:12 am »
I've done it both ways.  Someone screamed that you should always prime before layering adhesive on but at the end of the day, I really didn't know a difference.  In the end the adhesives were strong enough where they held through.
