Author Topic: Need some advise on how to tweak the coins mech  (Read 1582 times)
Reg
  • Last login:April 27, 2004, 10:43:45 pm
« on: September 29, 2003, 09:18:56 am »
Hi,
My coins mech refuse more quarters that it accept them! :-(
How can I tweak it to accept more quarters?
thanks
Reg
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:Need some advise on how to tweak the coins mech
« Reply #1 on: September 29, 2003, 10:15:52 am »
Some coin mechs have an adjusting screw on the back that allows you to tweak it... others you have to investigate how it works and bend a few pieces to make sure it allows your quarters. Another option is to just purchase the proper coin mech.
Do you have a US or Canadian coin mech and are using the other coin? Do you have a token coin mech that's almost the same size? Or is it just worn out? Some adjustment is definitely possible but coin mechs aren't very expensive either if you continue to run into problems.
« Last Edit: September 29, 2003, 10:16:12 am by Brax »
If you build a frankenpanel, chances are I don't care for you as a person.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: November 02, 2003, 01:10:39 am »
What brand are they?
Reg
« Reply #3 on: November 03, 2003, 07:58:00 pm »
Hi,
There are accepting 1$ Canadian coins
and they are Coin Mesh ElmHurst.
thanks
Reg
Ken Layton
  • Guru
  • Technician
« Reply #4 on: November 04, 2003, 12:17:07 am »
I believe that Coin Mechanisms, Inc. has the manual for your coin chutes available to download from their website of: www.coinmech.com
You probably have the "100" series mechanical units.
