Author Topic: 29/27 viewable Makvision tri-mode  (Read 5431 times)
reaper420
  • Last login:May 07, 2012, 03:12:34 pm
« on: April 03, 2012, 11:42:00 pm »
I just got a new 29/27 viewable Makvision tri-mode monitor for my mame cab
got it installed,  I'm using a arcade VGA card
the dispay is uneven, the bottom left and top right corners are bending outward / kind look like they are pulled in the corners
can see this in mame and its really bad in windows
, i have tried adjusting it and can not get it resloved
was hoping you guys might have some ideas
thanks
MonMotha
Re: 29/27 viewable Makvision tri-mode
« Reply #1 on: April 04, 2012, 12:17:44 am »
The adjustment for this is "pincushion" or sometimes "east/west".  If you have the analog one (knobs on the adjustment board and no on-screen display), the adjustment for this is probably on the mainboard, not the remote board.
The digital version may also have a "corner" adjustment.  That can be used as a last resort, but pincushion is the primary adjustment.
reaper420
« Reply #2 on: April 04, 2012, 01:10:53 am »
it is analog , i have tried the pin but it adjusts both corners on the left or right side
its just the lower left and the upper right , so if i adjust the lower left to about where is should be, the upper left it way off and vice versa on the right
MonMotha
« Reply #3 on: April 04, 2012, 04:31:59 am »
That control would be "trapezoid", if the monitor has one, which many do.
reaper420
« Reply #4 on: April 04, 2012, 01:17:42 pm »
it does have a trapezoid but it does the both top or both bottoms corners together
i need to just adjust one top corner, and one bottom
MonMotha
« Reply #5 on: April 04, 2012, 05:44:40 pm »
Ok, then adjust BOTH parallelogram and trapezoid :)
reaper420
« Reply #6 on: April 04, 2012, 06:25:24 pm »
would be great if it had a parallelogram adjustment  :(
MonMotha
« Reply #7 on: April 05, 2012, 12:17:42 am »
Check carefully.  It may be hidden somewhere in the middle of the chassis board.
What adjustments do you have available to you?
reaper420
« Reply #8 on: April 05, 2012, 12:54:55 am »
This is what the manual lists
Contrast
Bright
v pos
v size
v hold
H hold
Pin
H size
Trapezoid
Rotation
V.line
S.cont
H. sub-hold
Focus
Screen
then the drives for the colors
thanks for the help
MonMotha
« Reply #9 on: April 05, 2012, 01:19:32 am »
A picture of a grid test pattern would be handy.
reaper420
« Reply #10 on: April 06, 2012, 01:24:08 pm »
I Will try and get one posted tonight
thanks
cnhartwel
  • Last login:November 23, 2024, 06:00:42 pm
« Reply #11 on: April 06, 2012, 04:02:41 pm »
I have the same monitor, recent purchase and the same issue. Plus the colors are uneven, has purplish spots and I'm not sure if the left and right side of the monitor should be as unclear as they are. The middle the picture and colors are sharp, towards the edge the colors seem to separate and I can see the red green blue separation. Overall, definitely disappointed in the monitor, not sure if the issues are fixable or not
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #12 on: April 06, 2012, 04:20:10 pm »
I purchased my Makvision about a year ago from Happ when they ran a sale on them.  Since then, I have had a number of conversations with Keith in tech support.  The issues you describe are quite common with the Makvision monitors, especially geometry issues.  Mine has a slight horizontal linearity issue.  I have also noted some spotting which I was able to correct with a degaussing coil.  You can probably find it cheaper elsewhere but here is a link from Amazon.
http://www.amazon.com/Waldom-Degaussing-Coil-Color-Power/dp/B00011UYJU/ref=sr_1_1?ie=UTF8&qid=1333743576&sr=8-1
