Author Topic: Mame at 120Hz and resolution lock in Win7  (Read 2092 times)
mrchrister
  • Last login:December 22, 2025, 11:48:23 pm
« on: July 21, 2011, 12:32:18 pm »
Hey guys short question...
I tried running my mame games at 120Hz
I had them run at 100Hz before and that worked quite well but for some weird reason i cant run the games at 120 right now...
Maybe this has to do with my switch to Win7 recently... In WinXP I locked the refresh rate in DXDiag. Does anyone know if I can lock the refresh rate in Win7?
My monitor is connected via VGA and I think the NVIDIA refresh rate lock only works with DVI unfortunately... any other possibilties?
« Last Edit: July 21, 2011, 06:32:40 pm by mrchrister »
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
Re: Mame at 120Hz and resolution lock in Win7
« Reply #1 on: July 21, 2011, 06:42:53 pm »
Just out of curiosity, why would you want/need 120Hz?
mrchrister
« Reply #2 on: July 22, 2011, 04:19:14 am »
I tried playing games on 60Hz but it really makes my eyes hurt. On 100 Hz everything was running great and no flickering! I had all the emus set up to use this refresh rate and you could play for hours without getting Eye Cancer...  :dizzy: The big problem though is that side scrollers run jerky at 100 Hz because most of them run on 60Hz natively. Thats why I want to double the refresh rate to 120Hz!
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
« Reply #3 on: July 22, 2011, 05:10:31 am »
With PowerStrip from www.entechtaiwan.com you can make custom resolutions and forced refresh rates.
mrchrister
« Reply #4 on: July 23, 2011, 07:19:17 am »
thanks! powerstrip worked!
