Author Topic: U5000 no picture/low frequency squeal  (Read 1758 times)
Q*Bert_OP
  • Oh yes, we did!
« on: April 28, 2011, 07:32:50 pm »
I have a U5000 monitor that I'm working on. It had a shorted HOT, replaced and the monitor fired up...somewhat...
It is making a "squeal" like a low-res monitor should, but at a much slower frequency. I am running in 15K mode. There is no picture, but the over current shut down circuit is not activating.
I did a full re-cap to this monitor chassis 4 years ago, but it hasn't been used since.
MonMotha
Re: U5000 no picture/low frequency squeal
« Reply #1 on: May 02, 2011, 12:58:59 am »
IIRC, this has a SMPS?  Check over in the power supply section for the squeal.  Switch mode supplies can do that if abnormally loaded or sometimes just during normal operation.  May still be a dead component that isn't drawing enough juice to shut it down.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: May 03, 2011, 12:11:20 am »
