Author Topic: 18mm and 24mm holes  (Read 4765 times)
Donkbaca
    • Slim built MAME/Xbox cab
18mm and 24mm holes
« on: March 07, 2011, 12:20:42 pm »
Getting some small seimitsu and sanwa buttons.  What is the best way to make these holes?  I am only using ONE 24 mm button and I would rather not get a forstner bit for one hole....
Woodshop Flunky
Re: 18mm and 24mm holes
« Reply #1 on: March 07, 2011, 02:06:53 pm »
If you have a router...
1. Make a circle jig out of scrap wood that will allow you to cut a circle slightly larger than your router base.  The size of the circle should be: half the size of your router base plus half the difference between the 12mm hole size and router bit size.
Equation: Circle Radius = ( Router Base Radius ) + ( Hole Radius - Cutter Radius )
2. Once you have this jig, you can cut a circle out of scrap to make a template for your router to ride inside.
Seems like a lot of work, but should provide a challenge. :)
« Last Edit: March 07, 2011, 02:11:05 pm by Woodshop Flunky »
Donkbaca
« Reply #2 on: March 07, 2011, 02:22:04 pm »
Nah, I have enough challenges :)  and I don't want to ruin my work because of sloppy holes, or spend an entire afternoon working on a circle jig.  Sigh, just bit the bullet and got some forstner bits.
Woodshop Flunky
« Reply #3 on: March 07, 2011, 02:54:16 pm »
I had the same issue... I bought a forstner bit for a single task.  But at least it's in my tool box now for the next time I need it. :)
llars
  • Last login:May 02, 2011, 02:01:46 pm
Donkbaca
« Reply #5 on: March 07, 2011, 06:18:35 pm »
those cut holes that are too big
llars
« Reply #6 on: March 07, 2011, 07:12:42 pm »
Looks like lowes has a 24mm hole saw. Try googling it. I cant link because it gives me a mobile url
Donkbaca
« Reply #7 on: March 07, 2011, 08:07:54 pm »
already ordered some cheal forstner bits from some chinese import company. Don't care that they are junk I only need to make 7 holes.
