Author Topic: how to de-static optix  (Read 1649 times)
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« on: January 16, 2011, 01:45:40 pm »
I just bought a sheet of 42" * 21" Optix (clear plastic) for my pinball table.
Its great but when I run my hand 1" over the surface i hear the cracking of static electricity
How do you de-static it? it wont let go of the fluff on it either
My MAME Build:
RandyT
  • Last login:March 31, 2026, 02:16:41 pm
    • GroovyGameGear.com
Re: how to de-static optix
« Reply #1 on: January 16, 2011, 04:02:50 pm »
Ground it?
Smeghead
    • MY MAME BUILDS
« Reply #2 on: January 16, 2011, 05:35:50 pm »
really? Run a copper wire to a table leg or something?
My MAME Build:
BobA
  • What Me Worry?
« Reply #3 on: January 16, 2011, 06:39:58 pm »
Plastic surfaces cannot maintain static charge if they are in a high humidity environment.  The humidity helps to reduce the static build up. If you wipe the plastic with a cloth trying to remove dust you just build up a higher static charge and make the particles harder to remove.   There are sprays for TV screens that are supposed to help reduce any static build up but I cannot say that I have ever seen one do a good job.
« Last Edit: January 16, 2011, 06:42:40 pm by BobA »
BobA
  • What Me Worry?
« Reply #4 on: January 16, 2011, 06:49:17 pm »
There are also static removers that use a stream of air that has been ionized.   They are used to bath areas where static reduction is important, such as certain sensitive electronic assemblies.   Static mats that are grounded to a water pipe and wrist straps are also used along with the electronic anti static generators.   Too expensive to use in this case but the method may lead to a cure to the problem.
RandyT
« Reply #5 on: January 16, 2011, 09:22:20 pm »
If it slides into a metal frame, then ground the frame.  If there's a hidden edge, you could try running a thin copper wire down the edge, seal it with a length of tape and connect it to a grounded piece of metal.  But check into the suggestion Bob made as well.  If you can find a cleaner spray with anti-static properties, start using it and see what happens.
