Author Topic: Mini-PAC refuse to get rom written.  (Read 1682 times)
speeder
  • Last login:January 15, 2011, 06:46:56 pm
« on: December 11, 2010, 02:33:42 pm »
I am trying to program a minipac, but it is not working, the WinPAC software says just that it failed.
Someone has a clue on that?
But other than that, it is working fine (even mouse buttons and all that I added to it, and the trackball).
BobA
  • What Me Worry?
Re: Mini-PAC refuse to get rom written.
« Reply #1 on: December 11, 2010, 04:19:53 pm »
Depends on which version you have.   On the older version there is a Alt~ROM Jumper Block that needs to be moved to allow it to be programmed.   Not sure about the newer model.
speeder
« Reply #2 on: December 11, 2010, 05:46:44 pm »
I tried to use the old version WinIPAC thing, and it failed.
But after that, the new version worked fine... :/
I wonder what changed when I tried to use the older version.
NoBullMAME
  • Last login:April 11, 2011, 11:23:34 am
  • Author, The No Bull MAME Guide
    • No Bull MAME Guide Blog
« Reply #3 on: December 29, 2010, 01:31:02 pm »
If you have a new version of the mini-pac (with one mini-usb connection, not two PS/2 ports) some of the older versions will not program it (at least with mini-pac selected under options).
But is sounds like you are now working, so it may be a moot point (except for anyone searching the forums with a similar problem).
Author,The No Bull MAME Guide Intro priced at: $2.99
