Author Topic: Converting CP into LED lighted.  (Read 3549 times)
rivacom
  • Last login:March 12, 2015, 09:30:58 am
« on: November 21, 2010, 10:04:04 am »
So I've decided, I really like the LED lit control panels and decided to do my own.  I love the one's that have multiple colors.  So maybe people can help me pick out all the parts I need.
I want these for the buttons http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=238
Also found these joysticks http://compare.ebay.com/like/130448125746?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=171744369212&crlp=1_263602_304662&UA=%3F*S%3F&GUID=6ef3c26712c0a47a2f44cc64ffc29fe2&itemid=130448125746&ff4=263602_304662
Does anyone know where to get these retail? or one's that change multiple colors?
Anywho, those are the two additions, what else would I need for this? Switches? New Wiring? LED Wiz?  I already have a Jpac for the controls, so if I don't need a LED Wiz, that would save me a few dollars.
Re: Converting CP into LED lighted.
« Reply #1 on: November 21, 2010, 12:38:23 pm »
If you want full color buttons, you'll need RGB leds (ie a single LED that has Red green and blue LED's embedded within it. To control those, however, requires 3 ports on an LEDwiz.
So if you've got a CP with 2 players, 6 buttons each and 2 sticks that are lit, that means a minimum of (6 + 1) *2 * 3 or 42 ports necessary. So you'll need at least 1 LEDWiz 32 port and one 16 port.
Plus, you have to have a 3 resistors for EACH LED (one for each color). Plus lots of wire. Plus a USB hub or enough ports to plug the extra devices into.
In short, it makes a pretty cool CP (if not a bit "circus'y") and it's not a HUGE outlay, but it'll cost.
And if you have a 4 player CP, ugh. Mine I used single color LEDs just as indicator lights, so it was a little simpler.
There's several projects on the boards here of full color panels.
BobA
  • What Me Worry?
« Reply #2 on: November 21, 2010, 02:16:03 pm »
Paradise Arcade Shop is a vendor in the Buy and Sell forum.  They have an online shop as well.
ParadiseArcadeShop
rivacom
« Reply #3 on: November 21, 2010, 05:45:09 pm »
Ok so let me list out my parts here and see if I left out anything.  I'm going to do away with the multi color(maybe in the future).  Let's stick with two color(Blue and yellow(Sabres colors =)))  Using the buttons like http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=341
So 6 button per person, plus 2 extra for player 1/2 and enter/exit buttons.
14 button = 2.15*14 = 34.40
2 Joysticks(http://www.paradisearcadeshop.com/119-paradise-led-bubble-top-arcade-joystick.html) = 25 * 2 = $50
LED-Wiz™ 32-port USB Lighting and Output Controller(Assuming single color uses 1 port each) $45
So $129.40 for the whole CP correct?(Plus wire costs?)
Also has anyone had experience with those joysticks?  Is it better to do a color led in a  white nob? or Clear LED in the Already colored Nob?  or just do A color led with the same color nob?
BobA
  • What Me Worry?
« Reply #4 on: November 22, 2010, 06:45:43 pm »
The list looks ok based on single color LEDs in the PBs.   The draw of that many PBs when all on will exceed a USB port max so you will have to wire the external power on the LED wiz so that a drive connector can supply the power.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #5 on: November 22, 2010, 07:00:27 pm »
You actually don't need to wire power to the LED wiz, it draws the power it needs for itself off the USB.  It also has a place that allows you to tap into the USB 5v to use for your lights.   That isn't that many lights, I think it should work fine if the USB is plugged into the computer, if you are plugging into a hub, make sure its powered and you will be fine.
You can also just tap the 5v line from a molex.   I am using 12v lights drawing power off of my computer power supply.  The only reason you would attach an external power supply would be if you are mixing voltages and want to use the banks, otherwise, you daisy chain the positives to the anodes of the LED's then you connect the individual grounds to the LED wiz along with the ground for whatever external supply you are using.
rivacom
« Reply #6 on: November 23, 2010, 09:41:30 am »
Great!
Donkbaca
« Reply #7 on: November 23, 2010, 11:37:24 am »
Just send them an e-mail, Bryan is super good about getting back to you. I got my buttons from them, the chrome bezeled ones.  I LOVE them, swapped out the standard micro's for their 20g micros.  Smooth as silk.  I had my brother in law make a comment on how sweet they were, and he's not even a big aracade guy.  Anyways, I had the same question regarding getting colored buttons and the same colored lights, colored lights and clear buttons or clear lights and colored buttons.  He recommended I go with colored/colored.  He even said that if I didn't like the way they looked, I could send them back and swap them out.
 My admin buttons though, are clear with colored buttons, and i think they look good.
I would just e-mail him, tell him the look you are going for and I am sure he will help you out.
Oh and if you are looking for buttons, give his a shot.  I dig them.
Mr.Ian
  • Last login:August 21, 2013, 09:28:37 pm
« Reply #8 on: December 15, 2010, 07:00:09 pm »
Hi, I have one of these joysticks from Paradise Arcade. Mine is a Blue Crystal Ball top, with Either a blue or White LED. This thing looks great unlit, and  :censored: amazing lit up.
I Also cant recommend the seller enough. Fantastic Communication, Great Products and very quick postage, and im living in Australia. My only gripe is that these are not yet available in RGB Leds
They are also listed on ebay, Here is a link of things for sale
http://shop.ebay.com.au/paradisearcadeshop_com/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
Havent used the joystick yet, still building, but by all reports they are great
you wont regret ordering a few
JohnnyRocket76
  • Last login:July 28, 2011, 09:17:26 pm
« Reply #9 on: February 07, 2011, 08:30:29 pm »
I dont mean to highjack your thread but does anyone know how to do this?
