Author Topic: Wierd button behavior - Ipac ps2 28 inputs - WinXp sp3 - Mame 133 - Mala 1.71 FE  (Read 1704 times)
Vebbo
    • Overaged Lucky Drivers
I discovered a "bug" in my setup. When i play fex. 1942 or Raiden (only tried those two shooters) it sometimes during play triggers button 2 (L.Alt) this also happens with player 2 controls. I tried to reprogram the ipac but no luck. I also saw that when in WinIpac program when i press button 2 on the player 1 controls it triggers the "File" in the menu and makes it active and i have to press button 2 again to release it. Is this normal behavior?
I also tried to assign the button 2 (L.Alt) to another key but same thing happens. It's not often but quite irritating. Anyone got some clues?
« Last Edit: November 02, 2010, 06:25:08 pm by vebbomania »
Vebbo
Vebbo
I have changed both player 1 and 2 buttons from default Mame L.Ctrl and L.Alt to , (comma) and . (period)
I downloaded the keyboard test from www.passmark.com and ran it. Then i tried to simulate a game of 1942 without pressing the loop button assigned to . (previous L.Alt). It took a while after some jiggling with the joystick and pressing the , (previous L.Ctrl) then suddenly after i stopped jiggling the joystick and only pressed the , it posted a .
The question now is what to do next. Check wiring? Settings in Win XP? Settings in BIOS?
edit: The same happens for player 2 buttons, did the same operation with player 2 button 1 and after a while it postet button 2 even i did not press it  :dunno
« Last Edit: November 01, 2010, 08:55:01 pm by vebbomania »
Vebbo
Vebbo
Here's another guy with the same problem as i and with almost identical setup http://forum.arcadecontrols.com/index.php?topic=95633.0
Problem is, there was no conclusion in that thread  :badmood:
Vebbo
Vebbo
 :duckhunt... reprogrammed the ipac 1 player buttons (1-4) with other keys and now it seems stable  :cheers:
Vebbo
