Author Topic: Would there be a problem using 24 Ga wire for button wiring?  (Read 1483 times)
Hoagie_one
  • Um....whats a cabinet
« on: August 07, 2003, 04:24:53 pm »
Dont want to overload something or fry a wire.  is 24 Ga Ok for buttons?
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:Would there be a problem using 24 Ga wire for button wiring?
« Reply #1 on: August 07, 2003, 05:20:39 pm »
I used 20 guage myself, but I don't think there is an issue with 24.  I'm sure someone can answer from experience though.
:) Rotate or die! :)
night
  • Last login:January 09, 2018, 02:08:19 pm
« Reply #2 on: August 07, 2003, 08:30:33 pm »
i wouldnt go smaller than 20.
if the wire is to small its hard to crimp the spades sometimes and it will pull right out
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #3 on: August 07, 2003, 10:37:01 pm »
There's very little load on it, so, should work fine. It may be hard to crimp though. If you've got it use it.
All Your Base Are Belong To Us!
