Author Topic: Will this PC run most of MAME's games? (including chd games?)  (Read 2091 times)
Rulkiewicz
  • Last login:October 22, 2010, 08:28:12 pm
« on: August 03, 2010, 05:17:15 pm »
P4 2.66mhz
2GB memory
300GB HDD
(I still need to get a decent AGP video card)
What do you think?
Ginsu Victim
  • Comanche, OK -- USA
Re: Will this PC run most of MAME's games? (including chd games?)
« Reply #1 on: August 03, 2010, 05:20:24 pm »
All classics, most 90s 2D games, a handful of polygon-based games, and a few CHDs. The stuff it won't run can be handled by other emus.
Haze
    • MAME Development Blog
« Reply #2 on: August 03, 2010, 07:52:01 pm »
P4 2.66mhz
2GB memory
300GB HDD
What do you think?
With a current build, probably not.  A P4 is too weak, it will struggle even with things like Killer Instinct 2 and you're likely to be borderline on things like the 3-screen Buggy Boy and underpowered for some of the heavier 2D titles like the Sengeki Striker since the recent improvements.
Clock-for-clock a P4 is significantly worse than the Core2 chips, with the i5/i7 stuff offering a slight improvement over those.
jholman76
« Reply #3 on: August 06, 2010, 04:00:01 pm »
i've had p4 2.8's running KI and KI2 with no problem. The key is to use Tiny/Micro XP and to have a decent AGP video card.
joe
Havok
  • Trade Count: (+17)
« Reply #4 on: August 06, 2010, 08:00:29 pm »
joe
With a current build? They key is to use an older build in that case. Really, to get what the OP wants, pick up a Duo Core, install 64bit Vista or Windows 7 and run Mame64...
jholman76
« Reply #5 on: August 06, 2010, 09:06:45 pm »
it was in the .13X releases. I think .131 or 132 recompiled.
joe
Havok
« Reply #6 on: August 06, 2010, 09:08:40 pm »
Not bad - just goes to show you how much of a system's resources get sucked up with a standard build.
