Author Topic: Long load times in MAMEUI .138  (Read 2157 times)
brownicus15
  • Last login:June 23, 2016, 09:06:19 pm
« on: July 30, 2010, 02:25:29 pm »
So, as I said, I'm running MAMEUI through Maximus Arcade.  Games still run perfectly, but starting the game is whats irking me.  I press the select button, and it just shows a blank screen for atleast 30 seconds, and then loads the game properly.  Is this just how it's supposed to work? or is there a setting I can tweak to change that.  I had save states enabled, but I disabled that because it helped it run a little faster, but is there something else to do?
Thanks,
brownicus.
Havok
  • Trade Count: (+17)
Re: Long load times in MAMEUI .138
« Reply #1 on: July 30, 2010, 03:46:11 pm »
Why are you running a GUI Mame with a front end? Seems kinda counter productive. Have you tried the command line version?
brownicus15
« Reply #2 on: July 30, 2010, 05:46:27 pm »
new to the whole, multicade scene.  I'm too stupid to compile the command line version.
bkenobi
« Reply #3 on: July 30, 2010, 07:24:29 pm »
You can try using a command line version without custom compiling to see if it will help load times.  If it does, take the next step and learn to custom compile.  If you get that far, look for Headkaze's MAME compiler 64.  It will do everything you need to do without much more that clicking a few buttons!
brownicus15
« Reply #4 on: July 31, 2010, 01:24:59 am »
alright, where do I find the command line version? just on the mamedev site?
bkenobi
« Reply #5 on: July 31, 2010, 02:12:51 am »
That's the official download location.
brownicus15
« Reply #6 on: July 31, 2010, 01:30:15 pm »
and I'm just looking at the "binary version" for windows, yeah?  and when it asks for the rom location via .ini file, do I have to compile that ini on my own?
bkenobi
« Reply #7 on: July 31, 2010, 02:29:48 pm »
Just download the binary Windows version and put it in your current MAMEUI directory.  It will probably need its own ini file since I don't think MAMEUI's ini will be compatible.  If you need to create a new one, just run "mame.exe -cc" and it will spit out a default one that you can then modify.
