Author Topic: Spray Paint For Glass  (Read 2221 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: July 01, 2010, 03:28:11 pm »
Hi what paint should I use to spray paint cocktail glass black
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
Re: Spray Paint For Glass
« Reply #1 on: July 09, 2010, 01:47:30 pm »
i've used rustoleum oil based paint. i thin with acetone and spray with through a  harbor freight gravity feed hvlp touch up gun.
i always paint the inside of the glass. looks great. this is how i make all my bezels for upright cabinets.
you can get it at homedepot or lowes.
« Reply #2 on: July 09, 2010, 03:21:31 pm »
I used the stuff designed for plastic without issue
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
« Reply #3 on: July 09, 2010, 03:51:11 pm »
i used a matt black car paint in a normal spraycan. ( hycote , cheap as chips budget car paint ).
as for any paint that needs to adhere to glass , you must add light coats , stopping for 15 minutes between each coat.
this will gradually build up the paint and the layer . make sure the glass is completely clean , i.e - no water marks or smudges / fingerprints.
take your time and have the glass masked correctly with tape beforehand.
and lastly, do not use a gloss car paint on glass . your asking for trouble if you do.
I may be a jackass , but im no fool !
gryhnd
« Reply #4 on: July 09, 2010, 06:49:47 pm »
Clean clean clean, that's the biggest thing.
I used a metallic blue...Rustoleum I think. Been stuck to the glass for 4+ years without issue now.
See here.
Completed: No Name Upright
