Author Topic: Sega Naomi Cab monitor issue  (Read 2242 times)
gratzme
  • Last login:February 08, 2011, 03:56:45 pm
« on: June 03, 2010, 03:17:18 pm »
Hi, I have a sega naomi universal cab, with a sanwa 29E31S 31k monitor in it. The problem i have is that the picture is too wide for the screen. The picture is about an inch too wide each side. The monitor has a seperate control PCB which has some adjustments on it. However adjusting the horizontal pot does nothing except pinch the picture so the vertical lines bow inwards. I do have a schematic for the monitor but not sure where to start looking to fix the problem.
Any help would be great, thanks
grantspain
  • Last login:Today at 02:58:03 am
Re: Sega Naomi Cab monitor issue
« Reply #1 on: June 03, 2010, 03:44:32 pm »
i reckon look at q411,413,414 c423
gratzme
« Reply #2 on: June 03, 2010, 03:51:44 pm »
Thanks for the quick reply, i have a multimeter but am a newb to monitors. Is there a guide on checking these components and what determins a faulty component? Also im from the UK, where can i get hold of new parts?
