Author Topic: Identify This Cab?  (Read 3310 times)
mordzy
  • Last login:August 19, 2010, 05:25:45 am
Identify This Cab?
« on: May 18, 2010, 03:32:39 pm »
Hi All, My first post.
I bought what i thought was a factory KI cab, my first purchase.
However after i have noticed some differences, such as the curved sides, coin doors and artwork not running to the edge. im prietty gutted but it was only £150 so all not lost.
i thought maybe it was a UK version as i have seen MKII cabs in this style, im in the UK btw
thanks for the help
« Last Edit: May 19, 2010, 03:52:18 pm by mordzy »
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
Re: Identify This Cab?
« Reply #1 on: May 18, 2010, 04:37:50 pm »
I have no idea what this cab may have been in a previous life, sorry.  You may want to take some different pics though.  I would recommend getting full exterior cab shots, instead of close ups of the monitor and the cab top from the inside???  Try to get from the top to the bottom from both sides (with the top side up, I was getting sea sick from going left to right to left to ...) and a full front shot too.
Congrats on the nice find though.  I wanted KI cab with the art work intact but had to settle for a NFL Blitz / NBA Showtime instead. :'(
mordzy
« Reply #2 on: May 18, 2010, 04:49:57 pm »
yeh sorry about that,  ill take some better ones when i have room
i only took shots of the right side as the other had no artwork. the artwork you can see is damaged. i want to restore the entire cab however since its not factory im not sure if i should find a proper midway cab.
i have the option of a war gods cab pretty cheap which is a proper midway cab. i feel if im doing a full restore it should be authentic.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: May 18, 2010, 06:25:20 pm »
My neck hurts.
I'm going to take a wild guess and say KILLER INSTINCT?!
NO MORE!!
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: May 19, 2010, 01:26:10 pm »
My neck hurts.
+1000  :angry:
If you are in the UK, then all bets are off regarding "factory" cabs -- most of the time you didn't get the same cabs that folks in North America got.
For future reference, try using the img tag when posting pictures (after you rotate them, of course!)
Code: [Select]
[img]www.uplinq.net/ki/P1230026.JPG[/img]
gives you
 :afro:
Working: Not Enough
Projects: Too Many
Progress: None
mordzy
« Reply #5 on: May 19, 2010, 03:16:07 pm »
with you on the pix. im really sorry to all but its my mac. it auto rotates all pictures, somehow it knows what way up they are, however when i upload them they are normal, somehow even if i open them in photoshop they are the right way up.
I have had to rotate them save them, rotate back and save again to get right - bloody annoying but done now.
what would you guys suggest from an authenticity point of view, trying to keep as faithful to the original as possible? hold out for a 'known' midway cab to do a restore on, or go with what it comes in, taking into consideration that this cab i have needs sanding / filling and new art work (there is no art work on the left side).
« Last Edit: May 19, 2010, 03:49:00 pm by mordzy »
RayB
  • There's my post
    • RayB.com
« Reply #6 on: May 20, 2010, 01:55:19 pm »
It's complete enough that if you bought it for KI, I would keep it as KI and just clean it up.
NO MORE!!
« Reply #7 on: May 21, 2010, 06:41:38 pm »
welp, I love being a scavanger, but if you arent gonna keep it KI/KI2 I should could use the PCB/HD for my Killer Instinct
supra 59
  • Last login:August 16, 2010, 11:37:38 am
« Reply #8 on: May 21, 2010, 09:00:45 pm »
Hi,
Good luck for your work,at the moment I do the same thing as you,I bought a killer-Instinct cabinet,but not modified,his side-art are a bit damage but in a few week ,it'll be like a new one.
I'll be happy to help you if you want plans or some pics.
Good luck.
tornadoterry
  • Last login:June 09, 2010, 08:08:05 pm
  • I really did build my own arcade controls!
« Reply #9 on: June 09, 2010, 07:07:48 pm »
it is a UK cabinet. May very well be a dedicated version for them. Deith Lesure is located in the UK
Terry the Tornado!
grantspain
« Reply #10 on: June 09, 2010, 07:30:14 pm »
that was originally a mortal kombat cab-pretty standard u.k cab
