Main > Main Forum
Street Fighter 2 CE won't turn on
<< < (2/2)
Guywiththegun:
I will check again at home (@ work now) but I'm 80% sure I do get something similar.
grantspain:
make sure the jamma connector is on the correct way round
Guywiththegun:
--- Quote from: grantspain on December 22, 2009, 03:42:21 pm ---make sure the jamma connector is on the correct way round
Not sure what you mean? As far as I can see there's just one way it can possibly be on.
I checked the voltages again, it was a bit high but I got it down to 5.05, still nothing though. I keep hoping there's just something stupid I'm forgetting here.
If SF really doesn't need -5v then I am at a complete loss.
grantspain:
got a photo of the jamma connected to the pcb?
unless your jamma has a key way its very easy to plug in the wrong way round
very few game boards require -5,some need -5 for sound and some others used it for graphics
maybe we are looking at the wrong thing,try turning up the brightness/screen volts a little to see if you get anything on screen
Guywiththegun:
Here's a somewhat blurry one I took before I knew I could slide it out in the open. I can take better ones tonight.
It looks to be exactly like this:
http://chrisevans3d.com/hardware/xbox/jamma_pinout.gif
Something strange is the 2nd ground up isn't labeled as anything, just the first.
Navigation
[0] Message Index
[*] Previous page
Go to full version
