Author Topic: Coolest thing to build CP overlay out of.  (Read 1102 times)
Kman-Sweden
  • Up the Irons!
« on: November 02, 2009, 01:26:12 pm »
Found the coolest thing today.  ;D
Aluminium base, a picture of your choice then 5 or 10 mm of plexi on top of the whole thing.
Everything is laminated into one solid sheet. It would be really cool to use this as a CP top/overlay.
DillonFoulds
Re: Coolest thing to build CP overlay out of.
« Reply #1 on: November 02, 2009, 01:31:12 pm »
Except it's all autumn leaves and all...
Kman-Sweden
  • Up the Irons!
« Reply #2 on: November 02, 2009, 01:32:46 pm »
 :whap You can make your own overlay picture and have it laminated.
ammitz
  • Last login:April 25, 2017, 07:22:09 am
« Reply #3 on: November 02, 2009, 01:49:25 pm »
Where is the link..... ???
We want to see more
Building my first bartop CAB
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: November 02, 2009, 02:44:54 pm »
LINK LINK LINK
« Reply #5 on: November 02, 2009, 02:47:04 pm »
So... build the CP overlay out of the marquee?   ;D
Kman-Sweden
  • Up the Irons!
« Reply #6 on: November 02, 2009, 04:01:03 pm »
Dodn't think the link will do you any good.... http://www.crimson.se/?q=information/tjanster/montering
It's a Swedish photo/print company called Crimson. You might find similar products in your countrys.
DillonFoulds
« Reply #7 on: November 02, 2009, 04:06:15 pm »
I'm sure if someone here was crafty enough, they could outline it with some EL or maybe a couple cathods. Could have a pretty neat lightning effect.
bkenobi
« Reply #8 on: November 02, 2009, 04:08:49 pm »
Looks like the same technique used for epoxy topped work benches (among other things).  Take a solid, liquid proof surface.  Put pictures, screws, bolts, old whatevers on the surface.  Pour enough epoxy in such that the surface is all smooth and covering your objects.  Wait for it to dry.  This is an easy DIY project.  However, I had never considered it for a CP.  It would be VERY durable!
Kman-Sweden
  • Up the Irons!
« Reply #9 on: November 03, 2009, 01:40:56 am »
That could be really cool. Imagine a diamond plated sheet of aluminium covered with that epoxy.. You could even pour the epoxy over the EL... :dizzy:
DillonFoulds
« Reply #10 on: November 03, 2009, 01:05:15 pm »
Pretty sure the whole epoxy CP idea could end up in a few projects in the near future now... :)
bkenobi
« Reply #11 on: November 03, 2009, 01:31:07 pm »
It would work, but there might be easier ways to get the same effect.  Perhaps you could use a wood surface and then put your CPO on followed by a few layers of spar urethane.  It wouldn't be as thick, but it would be much easier to control the application.
