Author Topic: Control panel issues  (Read 2276 times)
bartre
  • Last login:March 19, 2018, 08:56:46 pm
  • I'm hesitating... again.
« on: September 12, 2009, 03:26:12 pm »
Hi all, gotten some pretty good help here in the past, but i've come across yet another problem :angry:
I'm using an ipac from ultimarc that i got a couple years ago, but the thing is, when i turn on my computer, it doesn't recognize the key inputs unless i restart, and i have to restart, if i shut down and turn the pc back on, the controls still don't work.
I'm pretty sure it's a windows problem because when i boot up the computer, if i set one of the keys to be f1, i can get to the bios and dink with that.
does anyone have an idea for me?
Re: Control panel issues
« Reply #1 on: September 13, 2009, 12:16:36 am »
What is the ipac doing when you first boot up?  Depending on what blinks and how many times you can troubleshoot it further by referring to the error codes:
http://www.ultimarc.com/ipac2.php
Also... since the ipac is independent (doesn't require Windows or software to run, since everything is stored on the ipac itself once you program it) I seriously doubt that it's Windows related since no drivers are loaded for the ipac.
Also, for troubleshooting, have you tried using a Win98 boot disk to get to the C:\ prompt?  Then try pressing buttons to see if any show up on the screen.  Do this from a cold boot (first turning it on) since this is the issue you are having.
But the LED on the ipac tells all.  I would check out the error codes first.
Good Luck!
DeLuSioNaL
bartre
« Reply #2 on: September 13, 2009, 05:20:28 pm »
well, i dinked around with the error codes, and sure enough, one of the switches was bad.
so i now have no error code.
unfortunately, that did not fix the problem.
any other ideas?
« Reply #3 on: September 13, 2009, 06:44:01 pm »
Double-check ALL of your connections.  You're probably thinking... I connected them all correctly.  But put your pride aside and actually do it.  (even if you think it's connected right).  I consider myself very experienced with building controls and every now and then, I'll connect a microswitch wrong which causes problems.  The most common error?  Connecting the wrong connection the the NC instead of the NO switch or reversing the ground, etc.
Give it a shot and see.
DeLuSioNaL
bartre
« Reply #4 on: September 13, 2009, 08:21:53 pm »
well, i double checked all of my connections and found 1 iffy one, so i redid it, and, nothing.
I took my cp as it is and plugged it into my normal desktop and viola! it worked, but it's still doing the same thing on my computer that i want to put in my cabinet.
so, the problem from what i gather isn't the iPAC, but my computer, unfortunately, i don't have a windows 98 disc to get me into dos before booting, so is there anything else i can try to fix it?
Hewskie
  • Last login:March 26, 2026, 04:32:03 pm
« Reply #5 on: September 13, 2009, 08:25:37 pm »
Back up everything and reformat? I love fresh installs  ;)
It's a pain, but it will probably work. I'm no computer genius and someone may have a much easier and simpler solution, so it's up to you, it's what I would do  :)
Hewskie
« Reply #6 on: September 13, 2009, 08:42:53 pm »
Have you tried using notepad in safe mode?
bartre
« Reply #7 on: September 13, 2009, 09:39:53 pm »
just did, it's the same issue there.
so, the light flashes, then stays lit, the keyboard doesn't work, i reset the computer, and the light never goes off for a second and it does work.
could that point to something?
« Reply #8 on: September 13, 2009, 09:51:44 pm »
I'm no expert, but it seems like something is wrong with the ipac.  I had a similar issue when my keyboard strokes would work intermittently.  I contacted Andy at Ultimarc and he sent me an IC chip to swap out on the ipac.  It solved my problem.
Did you try contacting him yet?  andy@ultimarc.com
Point him to this forum topic too, so he can see what you've tried so far.
DeLuSioNaL
« Reply #9 on: September 13, 2009, 09:55:05 pm »
How much do you have connected to that particular USB port (or is the IPAC connected to USB)?
If it is, and there's most than 400-500ma draw on the port, it could cause the ipac to function abnormally.
I was seeing that with my usb trackballs and U360's till I got a better, powered, USB hub.
Then everything just magically started working properly  :-[
bartre
« Reply #10 on: September 13, 2009, 10:01:43 pm »
the iPAC is actually an old one, it's a ps/2 iPAC...
« Reply #11 on: September 13, 2009, 10:04:20 pm »
That's the same one that I have.   It could be a good thing, since the newer ones don't have chips that you can swap out.
D
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #12 on: September 14, 2009, 06:44:23 am »
I am sure we can resolve this by email but one thing to try: If you have a keyboard connected to the pass-through port, try using a different keyboard on this port.
Andy
bartre
« Reply #13 on: September 14, 2009, 08:32:49 am »
tried it.
the keyboard always  worked.
YoGaBaR
  • Yeah im in the club
« Reply #14 on: September 14, 2009, 08:43:31 am »
I had this exact problem with mine. So I figured the computer was too old and I didnt want to mess with it. Since it worked on a different computer I just used the other computer. Let us know what solved your problem so maybe I can use the other computer in a different cab!
AndyWarne
    • Ultimarc
« Reply #15 on: September 14, 2009, 05:58:59 pm »
The easiest way around this problem is if I send you a USB cable and you can run the I-PAC in USB mode.
Andy
bartre
« Reply #16 on: September 14, 2009, 10:22:53 pm »
well, sure, but would the cable plug directly into the iPAC or would it just be a ps/2-usb converter?
