Main > Main Forum
No Sound on My Sega New Astro City
slapaham:
Hi chap
Well, as far as I'm aware, you don't actually need to use the sound amp on Jamma PCBs. I think the amp is there for other formats such as STV, etc which require an external amp (although I could be wrong on this!)
Anyway, sound kicked in completely randomly so I'm assuming there may be a loose connection somewhere - I'm hoping nothing too serious!
Thanks for the feedback, appreciate it! :cheers:
HaRuMaN:
--- Quote from: slapaham on July 28, 2009, 04:28:20 pm ---Anyway, sound kicked in completely randomly so I'm assuming there may be a loose connection somewhere - I'm hoping nothing too serious!
The culprit for this is usually the pot.
slapaham:
Are they easy enough to replace/sort? Also, is it a pricey procedure? :P
Cheers for the help
Zebidee:
Fiddle with the volume pot before you go and replace it - if the sound is scratchy and comes/goes suddenly as you adjust the pot, then replace it. They are very cheap & easy to replace.
slapaham:
Ah, that's reassuring, cheers Zebidee! :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
