Author Topic: Does anyone know where i can buy a 3.8mm NES Tool to open games locally not ebay  (Read 18652 times)
mrclean
    • Guscade
Looking for the security tool bit / screwdriver key to open up my old NES games where can i buy this item locally other than ebay, i already tried home depot, and radio shack
2,370,650 Gun.Smoke
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Do you have Harbor Freight close to you?  What type of bit do you need?  Security torx or ___?  If you have an Ace Hardware close, try them also.  I found what I needed there which surprised me.
mrclean
    • Guscade
looks like this :
2,370,650 Gun.Smoke
Mr. Gone
  • Last login:November 18, 2008, 01:09:39 pm
I remember a few years ago the place to get them locally was Sears. Not sure if that's still the case.
mrclean
    • Guscade
I'm near a sears / and ace maybe i'll give them a shot tomorrow
2,370,650 Gun.Smoke
Ken Layton
  • Guru
  • Technician
I doubt you will find that tool locally.
MCM Electronics (www.mcmelectronics.com) has the correct tool as their stock number 22-1145.
mrclean
    • Guscade
- Out of stock.
Ace hardware has a 33 bit set for 14.99 / and a 100 bit set for 18.99 i hope the one i need is in one of those sets
sears i couldnt find it online, may have it in the store though
2,370,650 Gun.Smoke
Franco B
I dont know what diamter the hole is that the screw is in but you should be able to use the biro trick.
Heat a biro up (or something plastic just big enough to fit down the hole) with a lighter etc until the plastic is molten and then jam the pen etc down the hole and over the screw. Wait for a few minutes for the plastic to set and then you should be able to unscrew the screw.
You may be able to use your new biro 'tool' to unscrew other NES games or you may have to melt the plastic for each one. If the screws are too solid this may not work but its worth a try before you go and spend any money. I used the same method to remove the screws from an N64.
fjl
  • Pixels Rule!
I have one of those bits. I think I originally bought it from Lik-Sang before they shut them down. Or maybe Ebay.
So what's wrong with buying it from ebay?
Namco
  • Last login:May 02, 2024, 08:30:10 pm
    • Freddo Mame Project
I got mine from Jandaman's
http://www.jandaman.com/games.mvc?p=gamebit38&Category_code=SNES
Looks like they're sold out right now, but send them an email, they might have one for you.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
In my security bit set (purchased at the local electronics shop), I have a couple of bits that look like slot-heads with a chunk cut out of the centre. I have these with success on Nintendo screws.
OTOH, I did order Nintendo bits online and use those now instead.
Working: Not Enough
Projects: Too Many
Progress: None
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Do the lighter and pen trick.  Just as Franco B mentioned, that trick usually works well.
Mr. Gone
The pen trick always worked really well for me with consoles (VB/GC/N64/. But for SNES/N64 games it never did the trick. They've got smaller screws and the holes they sit in are pretty shallow.
I know that for some of the really old NES games, though, a little flathead screwdriver will work. My Zelda and Hogans Alley have these screws. I was hoping my Mario Bros would, as it would mean perhaps it would contain the JPN->USA converter. (At USA launch I believe they didn't have the US game PCBs made yet, so they opted the half-assed approach).
