Author Topic: Best black paint to use on cab  (Read 2624 times)
onespriggan
  • Last login:March 13, 2010, 06:11:42 pm
« on: April 23, 2008, 11:05:44 pm »
Hello, can anyone recommend a nice black color to use on the sides of my cab?  Is one type better than another (like sherman williams black, or Home Depot generic brand)?  I know for the best results you have to thin the paint and sand over and over correct?
thanks
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: Best black paint to use on cab
« Reply #1 on: April 23, 2008, 11:09:49 pm »
I used rustoleum; oil-based enamel, eggshell finish. No thinning, and applied with a foam brush:
http://forum.arcadecontrols.com/index.php?topic=76724.0
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
protokatie
« Reply #2 on: April 24, 2008, 02:35:02 am »
Speaking of best black paint to use on a cab, I just bought a coinmech system off of thenasty which needs some TLC (mostly in the aesthetics dept). What would be a good paint and paint method for a coindoor? I was thinking to just mask over stuff and spray it with a flat black paint from a rustoleum can...And then give it a thin clear coat from a spray can as well to protect the paint... Anyone here touch up the paint on a coindoor and have suggestions?
mountain
  • Trade Count: (+9)
  • Last login:March 26, 2024, 11:42:28 am
    • Mountain Jukeboxes
« Reply #3 on: April 24, 2008, 07:07:19 am »
On my first machine, i took the whole coin mech apart an used a $15 sandblasting gun from Sears to remove the paint down to bare metal. I sprayed itwith a thin coat of automotive sanding primer and followed with 3 coats for Rustoleum Satin black. Turned out nice. You can find pics in my build thread (link in my sig)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: April 24, 2008, 01:20:46 pm »
Don't mask over... take the time to remove parts, clean them, and only paint those that need to be black.
I use many many thin coats of Tremclad Semi-gloss anti-rust spray paint. Bake the parts in the sun for additional hardness.
NO MORE!!
Jdurg
« Reply #5 on: April 24, 2008, 01:46:28 pm »
For my coin-door, I used Rustoleum Hammered Black Finish.  However, the finish came out a bit too glossy, so I then did a final coat with a normal Rustoleum Semi-Gloss Black.
After I finished, a buddy of mine asked why I didn't go to a local Auto Parts store and pick up a can of the truck-bed liner stuff.  It's textured like the original powder coat should be, black like I want it to be, and dried into a rock hard shell which will be very durable.  If I ever need to restore another coin door, this is the path that I will take.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #6 on: April 24, 2008, 04:21:42 pm »
I have used Rustoleum Painter's Touch Semi-gloss black from Home Depot applied with a white foam roller and obtained great results.
I am currently using Olympic (I think) Pure Black Gloss from Lowes applied the same way, and I don't like it as much as the Rustoleum.
The Rustoleum stuff does not come in Gallon cans (at least not where I go).  I am going back to Rustoleum once I use up this can of Olympic.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
onespriggan
« Reply #7 on: April 24, 2008, 05:48:07 pm »
cool, looks like you all favor rustoleum.  I will check home depot and see what they have.  Hopefully they make them in gallon sizes.
thanks again
RayB
  • There's my post
    • RayB.com
« Reply #8 on: April 24, 2008, 11:37:17 pm »
I'm also testing a new option. It's a can of black spray paint that's called "Patio Finish". It dries to a "sandy" textured finish.
NO MORE!!
protokatie
« Reply #9 on: April 25, 2008, 01:02:56 am »
Let us know how that goes, I do want the finish on my coin door to be as close to the origonal as possible without blowing the budget. (also the paint job on the cab as well)
Also, I appologize to the thread owner for derailing the tread from how to paint a cab to how to paint a coindoor.
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #10 on: April 25, 2008, 02:20:51 am »
I second (or fourth?) Rustoleum Latex... the stuff dries amazing and with a couple coats (on wood at least) it comes out like a professional-feeling shelf, like, you know, when you assemble furniture and pull it out of the box; wood on one side, the thick black coating on the other.  And, with my wood, with the type of roller I used, it have that subtle texture which matched my coindoor EXACTLY.  Someone, literally, that my whole coindoor panel was a solid piece of material... which is why I thought of it for your coindoor TLC.
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« Reply #11 on: April 25, 2008, 09:12:13 am »
You should let us know how that turns out. I was thinking about using that as well, but have not had the guts to do it yet. If you like it, i'll probably end up doing it too.
onespriggan
« Reply #12 on: April 25, 2008, 05:59:03 pm »
No worries.  It's all information I can use later down the line.  Painting the coin door will be my next task anyway
« Last Edit: April 25, 2008, 06:01:44 pm by onespriggan »
RayB
  • There's my post
    • RayB.com
« Reply #13 on: June 06, 2008, 11:27:44 pm »
I just wanted to finish what I started here and report that I like the "patio finish" paint I tried. I used it on some carriage bolt heads and some leg caps. I have not used it on something like a coin door yet, but anyways... the finish is a nice sandy texture, much like the texture of a classic control panel overlay.
NO MORE!!
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #14 on: June 07, 2008, 12:46:51 am »
I ended up spending quite a bit more than I probably should have on my black paint, and it's because I didn't know that Behr makes a specific color called "Ultra pure black." Like a dumbass, I went up to the swatches on the wall at Home Depot, and without even asking any questions to the paint associate, I grabbed the "Cinema Star" swatch from the Disney section, thinking it would be black when I got it. It turned out to be more of an extremely dark gray, so I ended up having to ask them to add 8 oz. of pure black. I got the shade I wanted, but in the end I ended up with about a gallon of paint when I only wanted a quart, and it ended up costing me $30. Just tell them you want a very good, pure black color, and tell them it's for an arcade machine. They won't laugh at you for telling them what it's for.
thatitalian
  • The Revolution Is Coming...
« Reply #15 on: June 07, 2008, 06:43:00 am »
I am in UK and looking for paint.
I found this:
http://www.tooled-up.com/ManProduct.asp?PID=130471
Rustoleum is not common here. Is this the right one to be using? It says it for metal!
RayB
  • There's my post
    • RayB.com
« Reply #16 on: June 07, 2008, 04:33:11 pm »
I found this:
I'm not clicking any link that has "man product" in the URL!!  Nice try rick roller!!
NO MORE!!
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« Reply #17 on: June 08, 2008, 04:59:47 am »
why dont you try this link for uk http://www.rustoleumdirect.co.uk/
i might get a tin of this, will prob be better than delux or spraying
thatitalian
« Reply #18 on: June 08, 2008, 06:45:49 am »
I found this:
It is a serious link!
If I wanted to Rick roll you I would have sent you here:
Which one do I get though?
« Last Edit: June 08, 2008, 06:47:47 am by thatitalian »
onespriggan
« Reply #19 on: June 08, 2008, 10:48:04 pm »
Also, should I be applying a primer on the wood before the actual paint or is this not necessary?
Q*Bert_OP
  • Oh yes, we did!
« Reply #20 on: June 08, 2008, 11:14:52 pm »
I'd agree with this, except I use a foam roller instead.
For the coin door, I also use "hammered black", but it's too gray for my liking, so I go over it with flat black, or semi-gloss black(whichever finish the coin door came from the factory with)
