Software Support > SK Jukebox
Howto Fix the missing "R" in SkJukebox 3.0 On-Screen Keyboard
superbigjay:
--- Quote from: Space Fractal on March 23, 2008, 01:25:08 pm ---Mightbeen I should create a little "unofficiel" patch the exe with the little typo bug? Cant se any problem about it, since the author have (to been sad) leaved the project with few bugs left (here one of them unofficiel fixed).
Do you want me to send you the patched binary or did you patched it on your side?
superbigjay:
--- Quote from: gonzo90017 on March 24, 2008, 12:54:34 pm ---I notice that when using the "Find" function the bottom boxes are cut off almost making the feature useless. Would be nice if someone can fix that. :cheers:
In what resolution are you running at?
SKjukebox doesn't scale the on-screen keyboard / find screen / list screen.
So if you're running at low res like 800x600, some boxes are too big to fit in the screen...
This is too hard to fix without the source code which is unavailable...
Jay :cheers:
gonzo90017:
I'm running it at 1024x768 full screen. The find function appears the same way it does in your screenshot. (without the taskbar of course)
superbigjay:
--- Quote from: gonzo90017 on April 01, 2008, 12:03:18 pm ---I'm running it at 1024x768 full screen. The find function appears the same way it does in your screenshot. (without the taskbar of course)
yep!
it's because skjukebox doesn't scale the on-screen keyboard and menu based on the screen resolution.
When I tried it on my PC my res was 1280x1024 on which the FIND menu with the on-screen keyboard fit in the screen. I tried it at 1024x768 and get the same problem as you ... you can't access the bottom boxes...
As I said, without the source code, that one is almost impossible to fix...
Jay :dizzy:
PS: I'll have the same problem on my cab since I'm running at 800x600 (TVO) :cry:
hitandrun:
Think you could find the size for "album screensaver" and make it the size of v4? BTW, great work!!!
Navigation
[0] Message Index
[*] Previous page
Go to full version
