Main > Main Forum
Self Adhesive vinyl and 3m sprays
waveryder:
They sell it at staples and hobbycraft. Not as strong as display mount though.
Fozzy The Bear:
--- Quote from: waveryder on February 07, 2008, 09:18:29 am ---They sell it at staples and hobbycraft. Not as strong as display mount though.
According to the technical spec published by 3M it's stronger than "Display Mount" which is designed for holding up photographs and pictures... This stuff holds up wood and foils and heavyweight card. I use it all the time I've glued plywood panels together with it in the past, after 5 years they still haven't come apart,
Best Regards,
Julian (Fozzy The Bear)
waveryder:
Wow better check that stuff out then. We use at school all the time I thought it was the strongest stuff in 3m's range. I'd better have another word with their rep I think!
somunny:
I prefer laminate so I normally use a brush on contact cement. Have you checked out this spray-on contact cement from 3M? Using a contact adhesive should should give you a longer working time.
3M Contact 80
ex_directory:
Wow, I wasn't gone that long was I - so many replies!! Thank you all!
Stan2323 - good tip, might do that, not like the vinyl adhesive is going to dry out.
MaximRecoil, yes I am using t-molding, but want to around the corner on the sides and under the t-molding if you see what I mean. Also, I am using vinyl for all the front and back panels too, so for them thought it would finish better if I go around to the back of the wood panel, will give a nice clean edge up against the sides rather than trying to cut there.
Wavryder, I tried warming the vinyl last night as even after priming and sanding when the vinyl goes on it is not perfectly smooth, if the iron was too hot it stuck to the vinyl, if it was cooler it scratched the vinyl. I tried a tea cloth in between and that didn't seem to do anything. Maybe I need a bed sheet or something less thick?
Fozzy, I have just sourced craft mount at my local art shop - thanks for that, will give it a try instead of surfacemount.
I am still testing pieces without the laminate on top, i.e. just test pieces of printed vinyl, so my issue will only get worse when it is laminated, i.e. to try and go around the corner. I may try scoring it somehow.
Ex
Navigation
[0] Message Index
[*] Previous page
Go to full version
