Main > Main Forum
attatching power pad to computer
<< < (2/2)
shardian:
Joy2key
ChadTower:
--- Quote from: rachelb on December 17, 2007, 11:25:49 am ---can i hook the pad up to my computer and write an email with it, for example?
Not unless you find a pad with a hell of a lot of "buttons" on it.  Most aren't going to come anywhere near 26, even with combos.
knave:
There are PC dance pads around that register as a USB gamepad.  I picked up one of the Kraft free ones and it would work just as you say along with Joy2key.
Joy2key maps keystrokes to your gamepad buttons.
SavannahLion:
You could always model it after Twiddler or phone style keyboards. Multiple presses on the same button would select a different letter/number.  :dunno
In the end though, I get the feeling that any hacked solution you come up with isn't going to be very satisfactory for you. At some point, you're going to have to work out a solution which either involves hacking an existing DDR pad and fussing with some relatively complex software to get the key button presses or constructing your own DDR-eque pad using something like KeyWiz(s) to capture the keystrokes and futzing less with the software side.
If it were up to me, I would op to futz less with software and more with hardware. Ensuring you get the hardware keystrokes sent to the computer in the fashion you want gives it more portability for the project. Especially considering that you're using an Apple (OS*?) and others who would want to copy your work are more than likely using a windows based PC.
rachelb:
the joy2key software sounds promising.  is there a version for mac?  also, would the usb adapter and powerpad work on a mac?
what type of pad would be the best to work with?  ddr or nintendo powerpad?  i'd only need a few active keys on the pad (like 6 or so).
also, how much do these things go for (usb adapters, pads)? i would probably need 3 or each.
thanks so much
Navigation
[0] Message Index
[*] Previous page
Go to full version
