Main > Software Forum
What OS to install?
muzland:
Hi,
Most Dell's I know need the CD drive to be setup as Cable Select, not master or slave. I encountered this problem a few weeks ago and googling solved my problem. Could this be the issue?
Does the bios detect the CD drive? If it does then it is probably not Cable Select that is the problem.
Cheers
Muz
SGT:
--- Quote from: slycrel on December 18, 2007, 02:22:34 am ---The short answer is you need a DOS CD-ROM driver for your CDR, you should be able to get one from the manufacturer... The page linked above by EwJ that has the oakcdrom.sys would be a good place to start, it's got instructions linked close by as well. I used that doing tech support for cybermax computers back in the day.
The win98 boot disk that was linked already has the cd rom drivers. I have used it on a thousand computers and never had one that would not work.
slycrel:
--- Quote from: SGT on December 18, 2007, 08:33:16 am ---
I wasn't meaning to offend, I just was trying to sum up some of that. I don't have the means to try out your boot disk, I had to stick with what I know works, thus my comments. There are lots of options out there.
SGT:
--- Quote from: slycrel on December 18, 2007, 01:03:21 pm ---I wasn't meaning to offend, I just was trying to sum up some of that. I don't have the means to try out your boot disk, I had to stick with what I know works, thus my comments. There are lots of options out there.
No! No offense taken. Its all good. :cheers:
loadman:
Vic=20 'Press Play on tape' .. Good Times... Good Times
Navigation
[0] Message Index
[*] Previous page
Go to full version
